Gauge block handbook.
Likes Likes:  0
Results 1 to 7 of 7
    Aug 2008
    Californeeeah
    1,481
    45
    314
    Default Gauge block handbook.
    While searching for techniques of using gauge block, I came across this link. More than you'ld want to know.
    http://ts.nist.gov/MeasurementServic...load/MN180.pdf
    Jul 2005
    Midlothian, Virginia
    2,610
    70
    225
    Quote Originally Posted by Forestgnome View Post
    ... More than you'ld want to know.
    Indeed. Though it is nice to know that the Airy points are 0.577L apart.
    Dec 2000
    Bremerton WA USA
    10,659
    40
    4168
    Got it! Thanks . I've been looking for something like this as supplemental material to hand out to my classes.
    Jul 2005
    2,610
    70
    225
    Nice old 1942 Pop Sci article about gauge blocks, with interesting photos:
    http://www.google.com/books?id=2SYDAAAAMBAJ&pg=PA108
    Pop Mechanics 1934 article with a picture of Mr. Jo himself:
    http://www.google.com/books?id=yt8DAAAAMBAJ&pg=PA830
    Sep 2002
    Arizona
    3,549
    769
    467
    Thanks for posting that! The section on the history of the inch is very interesting. I had no idea that the inch used for land surveying (39.37 inches per meter) was different from the standard inch (25.4 mm per inch, exactly). The difference is about 0.0002%, but I guess that adds up over long distances.
    Cal
    Dec 2007
    N.E. oHIo, USA
    2,357
    1371
    Quote Originally Posted by Cal Haines View Post
    Cal
    I've been using .03937 as my inch/mm conversion factor for many years. There have been some interesting "discussions" at times where I was told how inaccurate I am for using it.
    I have promised to use 25.4 if I ever build a moon rocket!
    Rex
    Nov 2005
    Maryland
    8,201
    746
    1103
    ...the inch used for land surveying (39.37 inches per meter) was different from the standard inch (25.4 mm per inch, exactly).
    The NIST Gauge Block Handbook has a good discussion of the inch and meter standards.
    The 39.37 inch/meter conversion factor was adopted in 1866.
    The 1 inch = 25.4 mm factor was adopted in 1959.
    I expect the 1866 inch continues to be used for surveying since all historical work was done using that value.
    - Leigh
