GD&T help needed. Box with line through it in relation to True Position
Results 1 to 9 of 9
    Feb 2013
    Madison, WI
    1,272
    1320
    816
    Default GD&T help needed. Box with line through it in relation to True Position
    Can someone tell me what the meaning of the rectangle box with the line through it is?
    This is off of a print from 1976 and is noted Geometric Symbols Per USASI Y14.5. I'm not finding anything on the Google, and I talked to the customer and they have no idea. There is also no rev change on that feature.
    Feb 2014
    FL
    4,395
    13712
    5265
    I'm forced to assume that that's a clerical error and they mean US ASME Y14.5, which was only implemented in 1973.
    I've never seen that symbol before, but it looks like a graphic for "Not Applicable" to me. What's Datum V? Is it possible that it has no relation to the keyway, so that's an N/A for its tolerance?
  3. Likes sfriedberg, AARONT, digger doug liked this post
    Feb 2014
    FL
    4,395
    13712
    5265
    I take that back, the original standard was ANSI Y14.5, which was superseded by ASME Y14.5. So yeah, that's definitely a typographical error. I'm digging to see if I can find a better answer for you.
  5. Likes AARONT liked this post
  6. #4
    Feb 2013
    Madison, WI
    1,272
    1320
    816
    Quote Originally Posted by TeachMePlease View Post
    I was thinking the same. Especially since it is where a value should be.
    We're going to put them in in the same op, so they should easily be within a couple thou of each other anyway. So I'm not too worried. Thanks for checking!
    Per Wiki-
    USASI Y14.5-1966
    Succeeded by ANSI Y14.5-1973
    Preceded by ASA Y14.5-1957
  7. #5
    Jan 2014
    Temecula, Ca
    3,381
    1413
    4405
    judging by how it's being applied, my guess is it's an obsolete symbol for symmetry
  8. #6
    Nov 2018
    Michigan
    754
    414
    501
    Looks to me like it's N/A on account of controlling a thru hole and therefore position being irrelevant. Missed opportunity for parallelism though, unless that is called out elsewhere.
  9. #7
    Jan 2020
    Connecticut
    55
    68
    17
    I don't think it was an error, the drawing was made with symbols from USASI Y14.5 1966 "Dimensional Tolerancing for Engineering Drawings." You can find a copy of it on Amazon: https://www.amazon.com/Dimensioning-.../dp/B001RS3IFI
    It is also listed in the inside cover of ANSI Y14.5M-1973: img_4616.jpg
    Seeing as it was drawn by hand, is it the original revision? I do have to agree that it likely just means not applicable.
  10. Likes gregormarwick liked this post
  11. #8
    Feb 2013
    Madison, WI
    1,272
    1320
    816
    Thanks for the input guys.
    pb1- The only Rev changes have been to heat treat and material. So unless I hear otherwise, N/A it is.
  12. Likes pb1 liked this post
  13. #9
    Jul 2009
    hope,in
    687
    33
    52
    I think this, the Z is Perpendicular to the face, ie Z. V is the position to the top hole. I think it could be Like '0 MMC'. X is the size difference allowable between the two Keyways slots. More of a hunch though.
