holes location inspection jig how ????
fisa
Jan 24, 2009
karachi
please looking help regarding the calculation of centre distance and plug sizes of a gauge for checking holes to holes ...
plwase check attachment for details
regards
asif
Asif,
Machtool is suggesting that your question does not come from an actual problem in a design office or tool shop, but that it's a question for a test or paper, either at your college or university or an employment test question to ascertain your understanding.
It looks altogether too hypothetical for him to take it seriously.
There is also not nearly enough information given to even begin to contemplate the merest possibility of formulating the nascent beginnings of a sensible reply.
ohhh ok ...brothers it is actual problem i am facing ...i have a little workshop and i have to make this checking fixture for my little quality shop...i am attaching details drawing in pdf format of that plate .i hope that now any one can understand it properly..
regards
asif
regards
asif
You're trying to find the correct location of 8 holes (several of which have a small tolerance) from the location of one? What is it you hope to check and why a 30mm thick plate?
Mission Impossible?
Making a functional gage for a part like this without proper design controls and the proper application of GD&T can make the use of functional gages impossible. Proper GD&T makes design and construction of functional gages very simple and straight forward. The print is almost unreadable, but I see no feature control frames on any dimensions so. . . ..
if i can explain the application of this plate holes ...then there is any possibility to define tolerances of specific holes for location gauge?
also i have find some standard for define tolerance ..but cant understand how to interpret or relate with this drawing. it .
