Hello,
My company makes several blocks that, functionally, are intended to be symmetric.
And every print has a "CL" centerline drawn.
My question is related to the fact that several different features are intended to be symmetric. Outside walls, inside walls, holes, etc. Which feature do I use to define the centerline?
The tolerance stackup allows for non-symmetry, and there is nothing on the print that actually calls for symmetry, except the centerline and several dimensions called from it. I've been told by both engineering and assembly the part functions best when symmetric, but they allow some tolerance in every feature for manufacturing. The problem I get back to is that since there are so many features, so much tolerance, which feature defines the centerline?
I ask because several feature locations are called off of centerline. But those dimensions are only called "once".
For example, a side wall from centerline is .500. That dimension does not call out 2X, nor is the other side wall dimensioned that way. Instead, the distance between both side walls is called out 1.000.
Another example, that really confuses me. The outside width is called out to be 2.000 with a basic dimension across both faces. There is another dimension from centerline to one of the faces at 1.000. This 1.000 dimension seems redundant to me as there are no additional tolerance restrictions. If that is the engineer's way of defining centerline, doesn't the tolerance allowed potentially shift the centerline away from the center defined by the 2.000 outside? And potentially away from the centerlines of the other features.
I would think the best solution for this part would be to use the symmetry GDT symbol. Define the 2.000 feature as datum A, call out other features symmetric to datum A. It seems to be the best compromise for manufacturing, design, and inspection.
I simplified some of the numbers and tolerances. But manufacturing sometimes has trouble staying to every requirement on the prints, related to this issue. The tolerances seem reasonable, but there are a a couple tight ones, that are in or out depending on how centerline is defined.
If anyone can shed some light on this issue it would be appreciated. All engineering tells me is that they are following the latest standard (defining centerline from an edge), but it would be nice to understand why it is defined that way.
