how to measure the diameter of this o-ring groove
Results 1 to 20 of 20
    Aug 2006
    Cape Cod, Ma
    490
    234
    119
    Default how to measure the diameter of this o-ring groove
    I'm looking to measure the .147 diameter +-.002 . I can kind of get in there with the tips of my calipers, but I'm thinking thats not the right way. btw this is a round part. I'm thinking maybe an outside caliper gage with ball points like this https://www.mscdirect.com/browse/tnp...SABEgK-vfD_BwE
    Sep 2014
    Minnesota
    238
    100
    146
    Picture doesn't get bigger when you click on it so hard to see for sure.
    Blade mic if it clears the thread.
    Aug 2006
    Cape Cod, Ma
    490
    234
    119
    Quote Originally Posted by mneuro View Post
    blade mic still has square ends. The groove is round. .044 thread clearance to the step. though I could turn the step back for clearance on a test piece to get a measurement..
    Sep 2014
    Minnesota
    238
    100
    146
    How about a point mic? that way you could get the smallest point on the radius.
    Mar 2017
    LATVIA
    623
    168
    327
    I'm only curious, did the designer specify +/-0.002" tolerance for a rubber oring groove diameter?
    and once the oring is squished, it is meant to touch the non-relieved end of the threads?
  6. Likes barbter, Ray Behner liked this post
    Oct 2007
    SPAIN
    4,353
    301
    174
    Quote Originally Posted by jz79 View Post
    My thoughts the same - with this design it will more than likely compression set the seal because there's nowhere for it to "go".
    I'll add, rightly or wrongly, I've never seen a design like it.
    OP - ref measuring it, you could use an Interapid Groove Checker - there's various types of interchangeable tips and some are very "pointy" with small rads on the ends.
    Apr 2013
    35
    13
    If you do not have enough clearance for a blade or point mic - which it seems you don't - check our Mueller Gage groove diameter gauge. Has replaceable legs and does OD and ID.
  9. #8
    Mar 2017
    LATVIA
    623
    168
    327
    I've seen fittings with oring in that exact spot, but the thread ended couple turns before the oring, so that when it is compressed, it has no chance of getting damaged by the thread, which will happen in this case
    and if the thread relief was added, one could make the thread relief diameter the same as the oring seat ID, making it much easier to measure if they indeed need the tight tolerance with something like the blade mic mentioned previously
    the other reason for thread relief would be that the mating part at that place has to have a face for the oring to seal anyway, so the "missing" 1, maybe 2 turns wouldn't have engaged anything in the mating part anyway, I'd extend the fitting a little bit to add those 1~2 turns in the front if possible
    sorry, just thinking out loud when I see these "impossible" parts...
  10. Likes Ray Behner liked this post
  11. #9
    Jun 2020
    South Carolina
    45
    15
    12
    You can use your blade mike you’ll just have to calculate the h dimension off the cord .The formula is in the machinist hand book bit of a pain to do all the math but it works. As for changing the design unless your customer goes along it can come back to bite u in the ass if you do it on your own and there’s a problem.
    Pete
  12. #10
    Jan 2002
    West Coast, USA
    8,878
    587
    6335
    Another option is to measure it over pins. A pin mic would have one of those pins fixed, make it less fiddly. Mueller gage with customer jaws a good idea if you're doing zillions of these. As others have said, the o-ring is going to deform more than .002" and the design itself subject to change . . . I'd wait a while to see about things like those near-interfering threads before paying for a set of custom anvils.
    On edit - as Gregor says - have to be tiny balls, if that tiny drawing has as tiny an o-ring seal as it seems. Bad idea.
  13. #11
    Feb 2007
    Aberdeen, UK
    4,160
    1475
    1785
    Quote Originally Posted by PeteM View Post
    No way to get pins on that geometry that I can see, drawing is too small to see clearly, but looks like it would have to be balls.
    If you can get balls in there, then two balls and a mic, although there is only .012" from the face to the centre of circular cross section, so not much to measure.
  14. Likes PeteM, johnb53405 liked this post
  15. #12
    Jan 2013
    Plainfield, Indiana, USA
    1,822
    1402
    967
    Looks like an optical comparator would get right in there ... after you take it out of the machine.
  16. Likes pb1 liked this post
  17. #13
    Aug 2006
    Cape Cod, Ma
    490
    234
    119
    The +-.002 is just a global tolerance for three place decimal dimensions on the drawing. The actual diameter isn't even directly called out just a radial dimension picked up off a diameter dimension. this is just a modification of an off the shelf tube fitting adapter low pressure application. They will not actually Q.C. these parts I was asking more as a learning opportunity for a hard measurement situation.
  18. #14
    Aug 2006
    Cape Cod, Ma
    490
    234
    119
    I just talked with the designer and found out that the tiny o-ring mates up with the chamfer on a threaded hole which does not have a max chamfer dia. called out
  19. #15
    May 2007
    Massachusetts
    881
    14
    77
    Blade mikes won't do it directly. Neither would point mikes, unless you had them custom made. Non-rotating spindle. The radius is R.035", so the spherical tip has to be smaller than that. the side of the spindle would have to be ground with clearance to get at the root of the cut (almost in half, but not quite). Blade Mike modification would be a radius one one corner, and an angle for clearance. I'd draw a picture, but I'm not there right now.
  20. #16
    Jun 2012
    Eastern PA
    1,084
    322
    507
    The ID of the o-ring groove is 0.146", no?
  21. #17
    Jan 2017
    Oregon
    3,992
    911
    2786
    Well, you know the OD of the part.
    Take it to the inspection plate, Pick up the groove with an indicator on your height gage or transfer stand, and transfer it to a gage block stack.
    Or zero the indicator on the groove, and pick up the OD. Note the difference on the height gage, and measure the OD with a mic. Now you know the groove diameter.
  22. Likes Bluejeep liked this post
  23. #18
    Mar 2017
    LATVIA
    623
    168
    327
    Quote Originally Posted by Bluejeep View Post
    so it is as I suspected, and it would look something like this: (the red line shows a possible cross section of the mating part
    and that would mean the last couple turns of the thread on the fitting aren't necessary and can be turned down to the ID of the oring groove giving you something you can directly measure and at the same time make the part quite a bit easier to make
  24. Likes Bluejeep liked this post
  25. #19
    Aug 2006
    Cape Cod, Ma
    490
    234
    119
    20200918_101330.jpgjancollc thats what I ended up doing. The pic was oriented correct on my computer . The digital height gage is great for this application touch off incremental points.
    Thanks all
  26. #20
    Nov 2018
    Michigan
    558
    284
    328
    Ouch.
    Glad you got it measured, cover yourself pretty thoroughly here since it sounds like you are making this for someone else and based on what I have read here, getting an -007 o-ring to perform its task in this application is nothing short of a small miracle.
    DON'T OVERFILL!!!! Compressed rubber has a poisson's ratio of 0.49999999, it is essentially incompressible. So when it deforms, the total volume available to the seal needs to be more than the volume of the part (especially in temperature swings, there are documented cases of steel hydraulic cylinders being ruptured by overfilled rubber seals that thermally expanded). 85% is a usual top limit, and I have gone as much as 90% fill in certain specialty applications, but if you don't have room for seal flow, it'll damage the seal and be more likely to leak.
    I doubt you have much pull in the design here, but I expect you'll try to stand by your work if there's a problem with the assembly and I think you'd be justified to do so.
    Sorry, just had to vent a bit on the "interesting" design. Best of luck!
  27. Likes barbter liked this post
