Keyence IM-7000 or Zeiss O-Select?
Results 1 to 4 of 4
    Jun 2017
    New York
    Default Keyence IM-7000 or Zeiss O-Select?
    Hello, Does anyone have any experience using either of these products? My shop is looking to measure pieces for quality assurance using one of these. We currently use OGP's smartscope which is a pain to program and we also use a microvue (but it is not automated). We were thinking of buying one of the machines to measure manifold slots, gasket compression, radius of a pressed on block fitting, header slots, and geometry of a radiator tube. I will attach photos.
    Also, if anyone has other ideas on how to measure these parts in an efficient and cheaper way please make suggestions.
    Jan 2019
    ITALY
    Hello, have you ever heard about Metrios? It's an alternative to these two systems.
    It's distributed by Vicivision America.
    Nov 2018
    Michigan
    161
    65
    92
    What's the length? Looks pretty long to go on that Keyence system, which I remember being quite small. I also don't recall the Keyence being much of an upgrade over our MicroVu, but we do have an automated one.
    If you're looking at Keyence, you might want to check out the VR series. It's not cheaper than anything, but it is very powerful and can give you a full surface profile of that radiator tube in a few seconds. You can even output it as a surface shell to compare directly to CAD for a GD&T surface tolerance if you have one. I'm close to convincing the bossman here that we need one
  4. Likes ivannedr liked this post
    Jul 2018
    33
    22
    8
    O-inspects are fantastic machines. I've written programs off-line that ran completely fine, having never seen or touched the device, mostly to the credit of Calypso software. Not enough experience with Keyence software to rate it.
    I've always found the OGP easy to program, personally...
