Jake E CEI
- Oct 11, 2018
Hi All!
I recently started a new position where I will be using a Laser Tracker to measure parts for dimensional conformity. Most of my previous experience is with CMMs and other types of layout gages (i.e. Optical comparators, Contour tracers, Profilometers, and most common hand gages) as well as I am moving from measuring car parts and small structural pieces of steel, to measuring a box a little larger than a shipping container.
I need to measure a set of Cylinders (3.5" Diameter, and roughly 3' tall) that will be set in concrete to anchor the large boxes we will be installing, the concrete floor would be equivalent to Datum A and I would like to inspect them for perpendicularity as all previous measurements performed on the cylinders prior to myself coming on board to this new company have been an X,Y,Z coordinates from the top center of the cylinders. While this info has been beneficial to my company for leveling purposes we are still having issues with bolt holes not lining up and my first thought was Perpendicularity being off.
My concern is trying to measure the posts with a laser tracker and trying to collect as many valid points as possible with out breaking contact between the SMR and Tracker unit. I do have one of the adapter for the SMRs with a center post on the bottom of the adapter and I will probably start there.
Just curious if anyone else has had to measure anything like this in the past and if you have how do you go about it. I am thinking I may need to get a custom adapter for the SMR.
