LTF Machinist's Level
Results 1 to 4 of 4
    Nov 2018
    ROMANIA
    8
    Default LTF Machinist's Level
    Hello,
    Just bought a machinist's level. It is branded LTF 0.35mm/m, 20cm long.
    0.35mm/m is not very sensitive and is good to get things in the ballpark.
    Does anyone know anything about LTF levels? Are they any good? The website is italian, so it indicates good origin, but they look suspiciously similar to the cheap noname china ones found on ebay
    LTF Machinist's LevelLTF Machinist's LevelLTF Machinist's Level
    Anyhow, I got it cheap and at least the base does not seem to have nicks or burrs (only scratches).
    Sent from my SM-A520F using Tapatalk
    May 2011
    New Jersey
    2,302
    204
    1258
    Does it say fragile on the box anywhere...that's how you know it's legit from italy.
  3. Likes M.B. Naegle, AARONT, Booze Daily liked this post
    Dec 2008
    New York
    10,224
    2656
    about .004" per foot common for setting machinery and shim calculations as obviously if 10x more sensitive you end up being off scale and not getting any reading to be able to calculate shims.
    i have seen 0.02mm/m levels before and normally you never use to set machines. they are more for measuring lack of flatness or sag for extremely fine adjustments in the under .001" amount normally
    picture showing a 0.02mm/m square frame level. it was useless 90% of the time til I added the 0.4mm/m (.005"per ft) level on it. literally after i added the less sensitive level i used it 10x more often
    most levels have a up and down and also a side to side adjustment. how vial attached matters. some vials just glued and if glue comes loose it needs to be redone. obviously vial needs to not move around when level tilted
    Nov 2018
    ROMANIA
    8
    I too want to use 2 levels. This one which is 0.35mm/m and the Heinrich Erb which is 0.05mm/m.
    But back to the original question: Does anyone know anything about the LTF brand? Is it a good one? Or is just a china crap with a printed label?
