Mahr Supramess repair
Likes Likes:  0
Results 1 to 5 of 5
    Aug 2008
    near Cleveland
    803
    51
    103
    Default Mahr Supramess repair
    Does anyone have a manual on the Mahr indicator? It's part of a dial snap gage, and is jammed/stuck. I have it partially disassembled-face is off so I can partially see the mechanism, but aren't sure what I'm looking for.
    Rich
    Ok, it's now unstuck, looks like it only needed lubrication. What instrument oil do the folks here prefer?
    Mar 2009
    Brunswick Oh USA
    4,461
    4907
    2654
    Default Mahr supra
    Machinest,
    You may want to try Machinist Tool Repair in Valley City. 330 483 3202
    Ask for Mike. They are quite knowledgeable.
    Ray
    Oct 2004
    Maryland
    113
    Default Instrument Oils
    http://www.ofrei.com/page246.html
    Synta-A-Lube
    Use very sparingly !
    Regards,
    Steve
    Sep 2002
    Salinas, CA USA
    3,869
    197
    172
    I'm not an expert, but I have read that one place you do not want oil is on the plunger, where it goes through the body of the indicator. I have had good luck disassembling sticky indicators, cleaning out the bore with brake cleaner and a small bristle brush, and the movement in an ultrasonic cleaner. Then apply oil only in a minute amount directly to the bearings and the rack and rack gear. I have some sperm oil intended for instrument repair that I use.
    Sep 2002
    Salinas, CA USA
    3,869
    197
    172
    I have a supramess that has the scale lettering upside down. i.e. the plunger needs to be upwards to read the scale. The indicator works fine in that position. If I turn it over, with the plunger down, it sticks. Are the movements sensitive to gravity and designed to work only in one orientation?
    -Dave
