peter.blais
Cast Iron
- Aug 21, 2006
- Salt Lake City, UT
Hi guys...
I'm looking at making some small diameter (~.375" bore) pistons and cylinders. They will be ground and honed, respectively- probably to a few tenths (hopefully) and then the task will be to measure them all up and make matched sets within about .0001". Now, we'll CNC turn them, heat treat, send out for grind and DLC coating as appropriate... I'm sure that I could have the coaters / grinders measure them and baggie them with the sizes marked on them. However, what's going to be the best way to measure this stuff to confirm it? I probably will make a few hundred of these sets per year, so if I'm going to gauge them in house, I don't want to spend more then a couple of grand on the tools.
Our shop is not WELL climate controlled- it varies from 62 to 75 deg F, but being they are very small, I could measure them in my office which is climate controlled. Or, I could wait for a time of day when the shop and parts ARE 68degF, and measure them then. Night time would work fine.
The pistons I don't think would be too bad- I probably just need a really good set of calibrated mics. The cylinders though are tougher. Doing some research, I keep coming back to air gauges. It looks like they are available used somewhat- quite a few on ebay- and then I would just need an air pin made, and a ring gauge that size...
The other option is to try to find a metrology place local and farm the work out. Receive them back in labeled baggies and just sort them.The fit of these parts is critical and the failure rate must be very low, so trusting the grinder / platers is not an option, at least not at first.
What do you guys think is the best approach in this situation?
