The meaning of a size dimension
Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Apr 2019
    Iowa
    Default The meaning of a size dimension
    I'm going to try and keep this question as simple as possible. Let's say you have a plate to be machined and your blueprint says the thickness of the plate should be .5000-.5006 for example. What EXACTLY does this mean? Obviously in a perfect world the plate would be like two ideal planes separated .5003 apart. But we don't live in a perfect world and the plate will have warp, low and high points i.e. the usual, however small, variation. I've read things online about the Taylor Principle, Enveloping Principle, 1st Principle whatever you want to call it. It says a feature must be "of perfect form at MMC and any deviation from MMC there is an equal deviation in form allowed." But what exactly does this mean? I get that it is required the plate fits inside an ideal gauge of two plates .5006 apart, but what else is required? Reference to Machinery's Handbook, (ASME) Y14.5-2009 or something official would be helpful. Do both sides of the plate have to be flat to within .0006 and parallel to the opposite side to within .0006 so no two points on the 3D surface deviate outside the .5000-.50006 range, or does the tolerance only apply to the thickness of opposed points, or exactly how does it work?
    Feb 2013
    Madison, WI
    953
    1094
    612
    It means the part has to be .5000-.5006. Anything else needed should be spec'd out with GD&T.
    May 2010
    DENMARK
    3,154
    4007
    12665
    Quote Originally Posted by michaelf1988 View Post
    Come back when you have a difficult question.
    May 2011
    New Jersey
    1,915
    173
    1038
    It's pretty straight forward, the plate must measure between .5000 and .5006 anywhere on the plate. Even though it may or may not be called out your parallelism (//) between the top and bottom must be .0005 or less tir. This is something that can be done on a bridgeport without issue.
    There are no specs or principals involved...ya make it under, ya make it over
  5. Likes Eric M liked this post
    Jan 2016
    New Jersey
    216
    66
    95
    Quote Originally Posted by plastikdreams View Post
    I disagree. If the customer wants it parallel within that spec they should specify parallelism, not just height. Design intent should always be specified, not assumed.
    I would be surprised if the customer didn't want it parallel in a case like this.
  7. Likes AARONT, Eric M liked this post
  8. #6
    Jun 2012
    Michigan
    9,948
    3356
    3563
    If the customer checks it with a micrometer it would check less than the high and more than the low..
    If the customer checks it an a surface plate with an indicator and two stacks of JoBlocks it would it would check less than the high and more than the low.
    Checking method can not be assumed..
  9. #7
    Feb 2011
    2,040
    1383
    876
    Tolerance = what does the end use or user tolerate.
    From my experience, if it's not on the print, it shouldn't be assumed. If the plate is marked .5000-.5006 thick, that's from anywhere across the plate, but not from everywhere across the plate. A better call-out would indicate .5000-.5006 over 12", or something to let them know that spec must carry over more than just the width of your standard micrometer anvil.
    Things like that are not assumed because they are not always necessary. Machinists and engineers alike who over-tolerance parts and jobs can actually lose you money. No one is going to pay for a jet turbine that is "about right", but also no one is going to pay for a garden trowel with certifiable dimensions of +/- .00005".
  10. #8
    May 2011
    New Jersey
    1,915
    173
    1038
    Quote Originally Posted by Pariel View Post
    How are you going to hold 6 tenths of thickness without having parallelism of about .0005?
    As far as warp, if you can't make a .5 piece of metal flat without warping you should find another trade.
  11. #9
    Dec 2014
    CANADA
    British Columbia
    1,275
    361
    581
    I’ve got some 1/4” x 3/4 cold rolled 304 bar right now that if you remove the skin on the 3/4 face it warps 1/4” over 12” on the long edge. So let’s not make our generalizations too broad.
  12. #10
    May 2011
    New Jersey
    1,915
    173
    1038
    Quote Originally Posted by Hazzert View Post
    Let me rephrase...
    If your .750 304 warps like a potato chip as described...I'd get 17-4
  13. #11
    Dec 2014
    CANADA
    British Columbia
    1,275
    361
    581
    Let me rephrase...
    Don’t even get me started, these guys just love 304... we even had it annealed. Now it’s only 1/8 over 12”
  14. #12
    May 2011
    New Jersey
    1,915
    173
    1038
    I don't envy you lol
  15. #13
    Jan 2007
    Flushing/Flint, Michigan
    7,587
    377
    6337
    Actually it's very easy to hold 4 tenths or less on thickness and be several thou out of parallel if you own a Blanchard or a surface grinder.
    Bob
  16. #14
    Jan 2019
    Arizona
    549
    36
    190
    Is this a real part or a hypothetical one? reason I ask if its just a thickness on a part that is lets say 3" long and maybe 1" wide it could be pretty obvious and simple.
    how every if its a let say 8" x 6" x .5006-.5000 thick plate with a ton of cutouts and peaks they will usually have other nomenclature in it. Like flatness, parallelism profile etc etc and to what datums -A- -B- -C- etc etc. hypothetical are impossible to guess , not to mention posting it will get a tons of different answers and only speculation which no one can be Right Or Wrong because all the info is not there. if its something you are running then you need to have the right info, cause otherwise your wasting your time making a part that could be wrong or just stupid simple.
  17. #15
    Sep 2015
    Tennessee
    498
    248
    385
    Quite easy in fact.
    Anyway, your concern over parallelism doesn't matter, since it's not called out. The spec called out means that a thickness check anywhere on the plate will fall between 0.5000 and 0.5006. End of measurements.
    You must not ever assume any kind of spec, if they wanted it they would have specced it. If you want to take the extra time and give them extra specs not on the print, be my guest.
  18. Likes BDGiven liked this post
  19. #16
    Jan 2019
    14
    5
    Technically, per Y14.5 there is an implied flatness since the form of the part can't exceed the maximum material condition (MMC) of any feature of size. In your scenario, if part is made to low end of tolerance, you wouldn't see more than .0006" flatness on a part that is per print. Most of the engineers that I've worked with aren't aware of this and don't necessarily want or need a part "per print" in that aspect.
    Assuming part needs to be checked per (ASME) Y14.5-2009 standard, any thickness dimension constrains the flatness of the two called out surfaces. Same applies to holes and shafts as well. In Y14.5 this is referred to as a "feature of size".
    1.3.32.1 Regular feature of size
    One cylindrical or spherical surface, a circular element, and a set of two opposed parallel elements or opposed parallel surfaces, each of which is associated with a directly toleranced dimension.
    Below is the envelope rule that you mentioned.
    2.7.1 Rule #1: Envelope Principle
    The surface or surfaces of a regular feature of size shall not extend beyond a boundary (envelope) of perfect form at MMC. This boundary is the true geometric form represented by the drawing. No variation in form is permitted if the regular feature of size is produced at its MMC limit of size unless a straightness or flatness tolerance is associated with the size dimension or the Independency symbol is applied
    My interpretation is that as long as any measurement taken on the plate falls within .5000/.5006 AND the form of the plate can fit between two theoretical planes that are .5006 apart, then the part is per print. However, most customers don't need that and especially don't want to pay for that even though that is what they are technically calling. It is better practice imo to call a flatness on something like this to open up the tolerance. A .010" flatness for example would override the MMC boundary per Rule #1.
  20. Likes in2glamisgirl, Lynn R. liked this post
  21. #17
    Sep 2015
    Tennessee
    498
    248
    385
    Thst would require the thickness to have a feature control frame. This was not stated in the example.
  22. #18
    Jan 2019
    14
    5
    Quote Originally Posted by Rewt View Post
    No feature control frame required. Y14.5 calls out a feature of size as any directly toleranced set of opposing planes, diameter, etc. Here's an example from Y14.5 2009 that shows this as well.
  23. Likes in2glamisgirl liked this post
  24. #19
    Sep 2002
    People's Republic
    2,956
    212
    2053
    There is no flatness implied
    They sell you shim stock in a roll
    There are some things that get implied, you cannot have a highly accurate dimension without a particular surface finish for instance, but flatness is not one of them
    Parallelism would be assumed to some extent, because you can only get so far out of parallel with a 6 tenths callout
    For all you know the the part could have a half inch of warp and be totally functional
    Has to be called out
    This is how you lose a quote when you start assuming things that simply are not on the drawing.
  25. Likes BDGiven liked this post
  26. #20
    Mar 2007
    Norwich U.K. & Marvao, Portugal
    388
    895
    177
    Default Size dimension
    So you put a piece of thick wall tube in a lathe. You turn the outside, lets say it's 8" dia. and it's round and parallel. Using a ball end mic. to measure with you bore the i.d. until the radial thickness is .5003. Cut a piece out of that tube, at any point it is .5003 thick. Does it get past inspection?
