Measuring the alignment of a slide dovetail with the adjacent face.
Results 1 to 9 of 9
    Apr 2019
    Arkansas
    49
    5
    20
    Default Measuring the alignment of a slide dovetail with the adjacent face.
    If you want to measure the parallelism of a dovetail with the adjacent face of a slide, how do you do it?
    I've got an idea for how, but I'd like to hear what others do. I'm interested in tenths level accuracy.
    Jul 2009
    Peoria, IL
    11,700
    50
    8951
    I'd use the search function of this site.
    Apr 2019
    Arkansas
    49
    5
    20
    Actually not a bad search function, but it didn't find what I wanted to know which is aligning a female surface. Some got close, but didn't shwo enough detail to be clear. I'll try some other searches.
    Apr 2013
    Damascus, MD
    1,397
    4007
    792
    A dovetail is formed by two surfaces (i.e. two planes intersecting at an angle). Since it is practically impossible to use directly the line of intersection, the best method is to use a cylinder tangent to the two planes (e.g. a ground pin resting between the two surfaces of a "female dovetail" or resting between a flat surface prolonging the horizontal plane of the "male dovetail" and the inclined plane).
    Paolo
  5. Likes Kai Kendall liked this post
    Dec 2008
    New York
    10,035
    2610
    i usually measure dovetail using pins or plug gages and a micrometer. a angle block and indicator sometimes used if just measuring parallel and not size
    by unscrewing rods on a magnetic base you can attach to a block or a angle piece and indicate many things. usually its 1/4-20 or M8 thread. also use a granite square and or straight edge on a surface plate. anything can be curved, wavy and or twisted. and many parts sag from their own weight. usually got to think about how it sits on a granite surface plate.
    curved and twisted parts often do that cause just clamping for machining the clamping forces can distort a part AND after machining when unclamped many parts will go bong or thunk and distort when free again. hard to describe but have seen many times.
    localized hardness variations in castings sometimes cause bumps or waves too when machining. again hard to describe but have seen many times. ductile iron although its stronger its higher strength and hardness and consistency makes machining it harder to do too. hard to describe. can easily spend more time getting things under .0004" per 40" when lightly clamped than to rough machine the part
    Apr 2019
    CANADA
    Alberta
    13
    Sep 2010
    Oklahoma City, OK
    4,185
    721
    1765
    Question needs more context to answer.
  9. #8
    Nov 2010
    UNITED KINGDOM
    976
    193
    236
  10. Likes Richard King liked this post
  11. #9
    Jul 2005
    Cottage Grove, MN 55016
    7,590
    4093
    4537
    Matra...thanks you for this. Very valuable info.
    There was another pdf about this on calculating. It disappeared. ?? Put it back on or Send that to me if you can revive it...
