Measuring angle/diameter of a bottomed internal taper
Results 1 to 10 of 10
    Jan 2016
    Florida
    28
    11
    Default Measuring angle/diameter of a bottomed internal taper
    I know normally id measure internal tapers with gage balls, but this taper is too large and i dont want to try to source 3" balls. How would you go about measuring the angle and the diameter at the small end of the taper? I figure i can make a tapered plug to check diameter(i would size and angle the plug using two rings) but whats the best way to accurately measure the angle of this bore? The tolerance is only +-30' but i'd prefer to be able to reliably measure it within ~5'. The print should be attached. This is just a personal project for myself as a newer machinist so I would like to execute it as precisely as possible
    Sep 2015
    Ohio
    1,091
    658
    1060
    Sine plate
  3. Likes Glorifire, Illinoyance liked this post
    Jan 2016
    Florida
    28
    11
    Quote Originally Posted by Booze Daily View Post
    Sine plate
    Lol thanks now im having a "duh" moment. Just stack the blocks for the sine and indicate the low spot at two points in the taper to ensure parallel with the base, right?
    Sep 2015
    Ohio
    1,091
    658
    1060
    Yep. Though in this case you may want to clamp your part to an angle plate so your gage block stack isn't so high.
    Jan 2016
    Florida
    28
    11
    Cool, thanks again!
    May 2010
    DENMARK
    3,257
    4016
    12706
    Re angle then a sine bar is best. Re the bottom diameter of the taper then that won't be as easy. What do you have available to measure with?
    Aug 2015
    Illinois
    1,372
    989
    589
    Jeez! This is a cavity in the bottom of a bench block. I would measure the angle with a protractor. I would get the big end diameter as close as I could with calipers and, if necessary calculate the dia. at the small end. Anything else is a wast of time.
  9. #8
    May 2010
    DENMARK
    3,257
    4016
    12706
    Quote Originally Posted by Illinoyance View Post
    I suggest you look at the drawing. While you're at it read the OP.
    What the OP wants to do and what you suggest are two very different things.
  10. Likes Ox liked this post
  11. #9
    Aug 2015
    Illinois
    1,372
    989
    589
    Quote Originally Posted by Gordon B. Clarke View Post
    A great example of over tolerancing a drawing.
  12. #10
    Sep 2005
    Oakland, CA
    2,436
    257
    650
    Find someone with a CMM? if not, remember you need to be on the exact centerline of the taper to get an accurate measurement- being off center has a huge effect on the angle you will measure.
