Measuring threads with 3 wires
Results 1 to 10 of 10
    May 2010
    DENMARK
    3,721
    4080
    12731
    Default Measuring threads with 3 wires
    There are many that use the 3 wire method for measuring external thread pitch diameter. Many seem to make it more complicated than I think it can be. One of the reasons it’s a PITA is that most micrometers have a rotating spindle. If done at the machine make sure you have something to catch a dropped wire.
    This is how I decided to do it long, long ago.
    Place 2 wires on the top of the thread and hold them in place by resting the micrometer spindle on the 2 wires. That the micrometer spindle rotates becomes insignificant. Close the micrometer by pulling up the micrometer anvil until the 1 wire can be slid between the thread and the micrometer anvil. You turn the micrometer spindle until the single wire and the two wires are held in position and you have a measurement.
    When the micrometer is “closed” you have the measurement result. After you’ve done it this way a few times you’ll probably never do it any other way. It applies to both three single thread wires and the type that “clip” onto the micrometer spindle and anvil.
    One hand is holding the micrometer that is keeping the two wires down and your other hand is for the single wire.
  2. Likes J Gilles liked this post
  3. #2
    Oct 2007
    SPAIN
    3,938
    2296
    1549
    I was always taught Plasticine is your friend.
    2x wires held together and have them on the fixed anvil under the part and pressure "up" the mic which also holds the them in place.
    Then either slide the top wire in by hand and wind the spindle down, or have all 3x wires in Plasticine and do it like this
    #16
    Three Wire Thread Measurement
    Dec 2004
    San Antonio, Texas
    180
    15
    216
    I had a small foam block that I would stick the wire ends in.
  5. Likes atomarc liked this post
  6. #4
    May 2010
    DENMARK
    3,721
    4080
    12731
    Has anyone tried the method I suggested? It is both easy and fast.
  7. #5
    Sep 2006
    Stillwater, Oklahoma
    1,482
    110
    814
    Quote Originally Posted by Gordon B. Clarke View Post
    Yeah, I do it all the time. But I still clear the chip tray just in case.
  8. Likes Red James, Gordon B. Clarke liked this post
  9. #6
    1,793
    103
    73
    No I haven't,I prefer Barbters method.
  10. #7
    May 2010
    DENMARK
    3,721
    4080
    12731
    Quote Originally Posted by camscan View Post
    "Prefer" is when you try alternatives. I'm not sure if you're being stupid or provocative or stupidly provocative.
    I doubt if you've ever made a thread much less measured one.
  11. #8
    Oct 2007
    SPAIN
    3,938
    2296
    1549
    Ohhh, so I wasn't imagining things - you had deleted it but because I called you on it, you un-deleted it LoL
    Gotta get your "I think I'm superior" 2nd line dig-in haven't you?
    I SMH...
  12. #9
    1,793
    103
    73
    What makes you think that I haven't tried alternatives? You doubt if I have ever made(I bet you mean cut) a thread,I doubt if you have ever made a friend.
  13. Likes Trueturning liked this post
  14. #10
    Oct 2007
    SPAIN
    3,938
    2296
    1549
    Thread rolling.
    Hmmmm...."Formed" is a better name but could that be called "make"?
    Asking for a friend.
    (No, not that friend but another..)
