Mitutoyo 8" Digital Caliper Battery Cover "Fix"
Results 1 to 3 of 3
    Sep 2006
    Lincoln, NE
    343
    10
    Default Mitutoyo 8" Digital Caliper Battery Cover "Fix"
    This is NOT a cure-all for the dreaded Battery Cover problem on the Mitutoyo 505 Series, but it may help those who've had problems with the cover not staying on.
    (If yours is missing, this won't help at all ...lol)
    The Battery Cover on my 8" Mitutoyo Calipers had lost an ear (I guess) and would not stay closed without some ugly Scotch tape on it.
    I noticed that the threaded hole where the screw that holds the thumb-wheel assembly from the back side is an embedded brass piece also accessible from the same side as the Battery Cover.
    A 1/6" drill bit will pass through the insert without harm and if the Cover is held in position will transfer drill through the Battery Cover. Just be careful not to drill into or through your own appendage; as that's not part of the procedure!
    Open up the hole in the Cover for clearance with 2mm, ~ .O80 (#45 drill works)
    A little cleaning and leveling up of the top surface for the head of the screw with a Dremel and it's ready to go.
    Biggest problem you'll probably encounter; finding a 2mm - 0.25 x 4mm long screw. But, that may be less costly than buying a new Battery Cover.
    Fortunately, I found one in my "Metric Screws" stash.
    mit-505-battery-cover_1.jpg mit-505-battery-cover_2.jpg mit-505-battery-cover_3.jpg mit-505-battery-cover_4.jpg
  2. Likes JohnEvans, johnb53405, pb1 liked this post
  3. #2
    Jul 2006
    Hillsboro, New Hampshire
    11,713
    2721
    8166
    Noice, but why didn't you use a Torx drive for extra security?
    Nov 2007
    marysville ohio
    10,370
    2920
    7046
    I have a few pairs with black electrical tape around the cover. not ideal but it gets the job done.
  5. Likes JohnEvans liked this post
