Mitutoyo height gauge
Results 1 to 7 of 7
    Dec 2016
    ZIMBABWE
    291
    17
    16
    Default Mitutoyo height gauge
    Hello,
    I'm searching for a height gauge.
    I don't need the accuracy of the 3000+ usd units (I think). I'm searching for something in between and came across the Mitutoyo digital height gauges.
    They got an instrumental error of +/- 0,03mm. I'm curious how repeatable they are?
    I'm happy if I can measure within 0,03mm.
    I would also like to use them as a tool presetter
    https://www.mitutoyo.com/wp-content/...HEIGHTGAGE.pdf
    Aug 2006
    greensboro,northcarolina
    2,335
    136
    546
    Repeatability is in the spec, says .01mm
    May 2010
    DENMARK
    3,027
    3993
    12663
    Repeatability accuracy of almost all measuring tools is usually (much) better than the measurement accuracy.
    For your intended use you could buy a new 200mm vernier one for €50 and a 300mm digital one for around €250. Not Mitutoyo but easily good enough for what you intend using it for. Same accuracy spec. as Mitutoyo.
    Dec 2016
    ZIMBABWE
    291
    17
    16
    The €250 digital height gauges are all import.
    Don't know if they work as good as the Mitutoyo...
    Nov 2007
    Orlando, FL
    384
    791
    144
    Unless you're in Japan, Mitutoyo is an import, too...
  6. Likes Gordon B. Clarke liked this post
    Dec 2016
    ZIMBABWE
    291
    17
    16
    Haha yes you're right.
    I meant China import
    All the same height gauges, just sold under different brands.
    May 2010
    DENMARK
    3,027
    3993
    12663
    Quote Originally Posted by tcncj View Post
    I've seen it with my own eyes. Mitutoyo parts being made in China. There's no problem with Chinese quality as long as "cheap" isn't your main priority.
  9. Likes Eric M, neanderthal mach liked this post
