Hi, everyone, long time reader, first time poster.
We have a bunch of comparitors in our shop. The one I generally use, because it's by far the best, is an old Scherr Tumico. Unfortunately, it's almost all the way across the shop and is often being used.
Ten feet away from my work bench is a Mitutoyo PH-A14. It's all hooked up, but it never gets used because the only way you can see the shadow is literally to get a big cardboard box and put it over your head and over the hood and even then you can barely see the part. The only way I can see it being useful would be in a room where you could turn off all the lights and make it completely dark. The Tumico could probably be used in sunshine and still show the part pretty bright.
Does anyone have experience with these units? If so, is the dim screen normal? Or did somebody do something silly like put the wrong bulb in mine?
