Morse #3, 1 16' 26'' , DIN4550 and 17/4 or 17-4 Taper?
apolkhanov
Oct 10, 2016
VANCOUVER, BC, CANADA
I have, perhaps, strange question but I was unable to find an answer to it despite my pretty good Googling skills.
Air cylinder in my office chair has failed so I started looking for replacement. I have learned that original cylinder was made by company called DANT in accordance with DIN 4550 standard which is a German standard for these cylinders. Now when I looked at numerous drawings I found that top side has a taper which is 1 26''16 or 1.4377 degrees which I later found is exactly same taper angle as in Morse #3. But when I was looking for replacement cylinder I found that many specify same taper as "17/4" or "17-4". My question is WHY? What notation is 17/4? Is this even related to the size of taper? I am just really really curious where "17/4" came from?
If anyone know please share!
I don't know if page 3 of this helps or not.
http://www.draftingzone.com/shoppingzone/6-1.pdf
Depends on how curious you are whether you buy this or not :)
DIN 455 - Office furniture - Self-supporting energized devices for the height adjustment of office work chairs - Safety requirements, testing | Engineering36
That taper has been used in office chairs for decades. In the old days was the 17/2- you could use a morse 3 reamer. They had issues snapping the neck off the cylinders, so it became the 17/4- same taper per inch as a morse 3 but closer in size to a stub morse 4. as I rcall 1.102 inches is the od of those cylinders. Most makers use interchangeable gas cylinders that I am aware of.
No idea the origins of the names.
Thanks WILLEO, I have not seen any cylinders with "17/2" taper. Fact that there was "17/2" kind of just adds to the mystery. Why "17/2"?
I have the same cylinder and was trying to determine if a 17/4 taper was the same as the taper on my cylinder. Measuring the diameter, i see across 1.4 inches about .05 in taper (half the diameter change) That is a long way from 17/4. However, in the post below, it seems the conclusion was the 17/4 was the same taper.
Appreciate any help here on understanding the taper if I am looking at this wrong.
