Mr. Haelscheir
- Feb 19, 2017
I started this thread as a clean slate for discussing LVDT purchase options and the techniques for using them. This acts as a clean followup to my previous thread, "Considering precision TIR and OD/ID inspection equipment purchase", where we ended up discussing anything but how to choose or effectively operate an LVDT linear gauge. On this thread, please refrain from discussing matters of equipment and how tight tolerances are going to be achieved on my machine. I am only concerned with metrology and gaining an actual answer to the questions addressed in the OP of the aforementioned thread. I don't want to move forward with any purchase until I have gained enough insight on the subject to make an informed decision.
Brands and type: Looking back at the OP of that thread, I describe the things I want to measure and why they are important. I want to move from the why to the how I am to conduct these measurements. So, with brands such as Mahr, Etalon, TESA and Diatest as well as the many models offered by each, how might I choose which is most suitable for me? Are there any advantages with certain brands? I don't need a long stroke plunger setup; I only need what is necessary for TIR inspection and OD/ID comparison.
Required equipment: I'm having trouble finding information on what equipment is actually needed to use an LVDT and get a reading. I am particularly at odds with the terms, "gauge amplifier" and "indicator" for electronic gauging. From what I figure, one describes the instrument, or "box", to which the LVDT is plugged in that translates the electronic signals into a displacement measurement, while the other is supposedly a separate item that conducts the "amplification". This is the main page I am consulting for equipment with which to read the Mahr 1318's output.
For the "compact amplifier", "column amplifier" and "measurement interface", these seem to mainly differ in input capacities, display methods and software support. Then there comes the "measuring amplifier". Is that instrument necessary or does it play part in improving signal conditions? Would the compact amplifiers be an "out of the box", general purpose signal reading system while the measuring interfaces would be more suited for industrial gauging systems (reading the operation manuals slightly helps)?
OD measurement: Lastly, provided that I have this equipment, how would I use the LVDT's output for precision measurement of OD's (I'd imagine that ID's are best measured with plug gauges, in situ machined or purchased)? Optical comparison and bench micrometers are out of the question; costs, and the work piece must stay on the chuck. So far, it seems that one of the best methods is through comparison with gauge blocks. As described in the previous thread, I could set up a hand held stand with a flat surface and an actuated head holding the plunger perpendicular to the surface (like a horizontal height gauge). With gauge blocks, an initial reading is obtained with which the diameter of the part can be compared. Do setups like this exist and what are they called, or would I need to machine the holder myself? Furthermore, could this be used in place of a precision digital micrometer?
I acknowledge that I am indeed very new to metrology.
Regards,
Mr. Haelscheir
Regards,
Mr. Haelscheir
