Need help finding the right micrometer
snocat_trf
Hot Rolled
Oct 22, 2002
Canton, South Dakota
I have a measurment I need to make and we need to use the data for SPC. the Mic I had in mind was a Mitutoyo 345-351, I called and even asked the Tech support guy:nutter: at Mitutoyo if this would work for my application, He told me that it had 2.5mm round anvils just like the 345-350 which is the 0-1" of the same style. The Mitutoyo information page on their website also shows a round anvil.
I ordered it and it came in,:toetap: well it was not what I expected.:willy_nilly: It had caliper style anvils with a radius on them, but the radius is not small enough even if I grind a chamfer on the sides of the anvils, it will not measure the slot in the part I need to measure.
I am trying to check a slot that is 47.10mm long and 3.5mm wide with a 1.75mm radius on the ends.
If anyone knows of a mic or off the shelf gauge that will work for this that has spc capability, Please let me know.
TIA
Snocat_trf
Try These
What about a phase II 103-130 0~1" electronic blade Mic...resolution listed at 0.0001"/0.001mm. or Mitutoyo 422-421 listed as spc output w/ 0.00005" resolution..and whop'in big price. blades at .030" should be thin enough to btm out in the groove?
Probably a feature better checked pass/fail with a go/no gage. You can't accumulate dimensional data for analysis but generally what do you care so long as the part fits?
If the customer insists of hard dimensional data, you can make a tube and rod coaxial thingy with a LVDT (?) on one end and something like a steep angle adjustable parallel on the other. Use a pistol grip or a pushbutton to actuate the parallel thingy so it wedges tight in the slot so the LDVT can determine the displacement from nominal. Calibrate it from a gage for repeat zero, I think there's a standard chip for converting analog LVDT signal to SPC.
I realise this is but a gloss of the actual concept but if you need dimensional data from hard to reach features you quite often have to make something. Yes it's expensive and a hassle. That's why pass/fail functional gaging is still with us.
Dial Indicator Groove Gage
How about something like this:
http://catalog.starrett.com/catalog/catalog/groupf.asp?groupid=585
Put your own tips on it and an SPC output indicator.
Cal
