Our shop just got into doing our own hardness testing due to several parts that were rejected by our customer for being too hard or soft, we were trusting the shop who did the heat treating to do a good job. So our shop just bought a Wilson Rockwell tester along with several several different test blocks. Most of what we make that needs to be tested are pump wear rings made from spin cast CA15 or CA40 that run together were one is softer than the other one, they have to be in a 50 point range from 215/265 BHN to 375/425 BHN so we have to convert the Rockwell numbers which is not a good idea I know but we are working on getting a Brinell tester also, I've noticed that surface finish has a lot to do with the results as well as how rigid and flat the part is. Also testing on a single ring can result in 3 or 4 points difference in readings if checked at 0-90-180-270 degrees, is this a sign of bad heat treating or material that isn't blended well? I just wanted any tips that may be useful, thanks.
