Newall Spherosyn Bleecon to sub D connector?
Likes Likes:  0
Results 1 to 6 of 6
    Aug 2014
    Tamworth UK
    7
    Default Newall Spherosyn Bleecon to sub D connector?
    Hi, my Bridgeport is fitted with a rather old Newall Sapphire DRO which connects to a pair of Spherosyn inductive encoder scales. These connect to the head unit via Bleecon connectors. I'd like to change the head unit for a more modern Chinese unit with more functionality. I was wondering if it's possible to make up converter leads to connect the old Bleecons to modern Sub D connectors? I do know that the Newall head unit has to be set to recognise the Spherosyn scales so am not sure whether the encoders output is compatabile with the inputs designed to take glass linear scales? I just can't afford a modern Newall unit but was hoping that I could get the functions offered by a modern 3 axis unit using the two existing scales and adding a new glass scale to measure the Z axis. Any thoughts gratefully received.
    Jul 2010
    eugene,or
    848
    86
    353
    Pretty sure the output signals of a spherosyn scale aren't in the quadrature encoding that a Chinese DRO expects. As far as I know, only Newall DRO's read those scales.
    Teryk
    Sent from my XT1710-02 using Tapatalk
    Aug 2014
    Tamworth UK
    7
    Thanks Teryk, I did think this might be the case. I suppose I'll have to sell the head unit and scales to offset the cost of a new system.
    GERMANY
    2,670
    1657
    945
    I think what Teryk wrote is correct, but if you want to be sure, you could contact the UK-based manufacturer of these 7-pin Bleecon to 9-pin sub-D Newall converters: Newall Scale/Encoder Adaptor Cable to Convert 7 Pin to 9 Pin D Type Connector 5055396141092 | eBay
    Aug 2002
    Regina, Canada
    2,338
    5
    71
    There is a Chinese clone of the Newall system made by Depp. About half price but still more then the common Chinese stuff
    Mar 2014
    United Kingdom
    26
    Hi Purity Vendetta, if you are thinking of selling the encoders please private message me with a price. Spherosyn will only work with Newall DRO displays as technology proprietary (secret)
