Newall Spherosyn Displays compatibility
gregoryk
Nov 2, 2021
I have a Newall Spherosyn system with a c80 display on my machine. Unfortunately, the display is not functional. I can borrow the Newall Digipac5 display. Unfortunately, I can not find information whether the encoders that worked with the C80 are able to work with the Digipac5.
I realize that the C80 has a DB9 plug and the Digipac5 has an 8-pin DIN (I saw a Newall DB9 to 7-pin DIN adapter on ebay, so maybe there is a chance to make an adapter).
Best regards
If you haven't done so yet? Newall is pretty good with there tech support and with having there manuals available for download here. Technical Support I know they also make a variety of plug adapters that might sort out your problem with a cheap off the shelf part.
Thank you very much for your advice, which turned out to be very helpful. The Newall website in my country also did a great job. Now I just need to check the information obtained. :)
