opinion on spi hole mikes
Likes Likes:  0
Results 1 to 4 of 4
    Oct 2007
    phila,pa
    18
    Question opinion on spi hole mikes
    Looking to buy the spi hole mikes,never had any spi tools.Are thay good tools,mitutoyo makes holtest micks but price is way higher,thanks steve.
    Dec 2006
    Washington
    286
    SPI is, or can be spotty. Low end stuff is well, you will be sorry (imho). The high end stuff is better. Depends on the who makes it. I for one would get Sunnen and call it good.
    Nov 2009
    long island NY
    23
    Default vmt46
    I have used but like brand new (in the boxes) mituoyo borematic pistol grip gauges. (2) seperate pcs. Range .350 to .425 w/ .375 set ring & tools also ..800 to 1.0 w/ .875 set ring & tools.(Accy. .00005) heads are interchangeable . other heads are avilable.# are 568-402 & 568-406 I think the new # is 568-431 & 568-436. check out mituoyo .com or any catologe. I looking to get about $ 650.00 ea.
    Vinny D
    Jan 2003
    Pittsfield,NH,USA
    360
    If you check out the long Island Indicator web site they disscuss the pros & cons of the available makes. If I remember correctly, parts are not available for SPI. I have some SPI hole mikes as well as B&S. They have worked well for me but as a HSM, they get less use in a year than a real machinist would give them in a day. I think the above comments are right on. In the long run the best tools are the cheapest.
