Part fixture: Vacuum on a diameter
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Nov 2018
    ALAND ISLANDS
    356
    160
    118
    Default Part fixture: Vacuum on a diameter
    Hello!
    We do lots of round parts of different shapes and sizes, but they all tend to have a similar .500 +/-.001 OD in one way or another. We've got a few variations on fixtures, but there's always a trade off.
    Is there a method of madness to hold a small OD using a vacuum?
    GERMANY
    3,739
    2523
    1538
    Quote Originally Posted by thunderskunk View Post
    Vacuum provides a pressure of 14.7 pounds per square inch or about 1kg per square centimeter. Your part has such a small area that the "clamping forces" from a vacuum would be about 3 pounds = 1.5kg. That's not nearly enough for any standard machining operations, not even grinding.
    Jan 2005
    The Netherlands
    6,875
    384
    2044
    Quote Originally Posted by ballen View Post
    Unless he applies vacuum on 180į of the the side Then it depend on how long the 0.500" feature is
    But I agree A collet would perform better You could go fancy with a air or hydraulic operated colletcloser
    Peter
    Nov 2018
    ALAND ISLANDS
    356
    160
    118
    To your point, 3# isnít enough, but keep in mind itís just going in a CMM after machining is 100% complete.
    Now that Iím rereading my original post, Iím realizing I didnít actually say this was for a CMM, just posted in metrology, so thatís on me.
  5. Likes ballen liked this post
    Feb 2007
    Aberdeen, UK
    4,811
    1781
    2369
    I'm not really sure how a vacuum would work holding an od. It can neither expand the part nor shrink the fixture, so what would it really achieve? The vacuum itself is not what holds the part on a vacuum plate...
    I assume you're struggling with physical workholding methods distorting the part?
    Nov 2018
    ALAND ISLANDS
    356
    160
    118
    Not quite. Weíve got a few ways we currently hold the parts; if you want to measure the front, you use a datum simulator on the back. If you want to measure the back, you use a v-block on the front. If you want to measure both, weíve got a thin clamp that sort of works, but recent data made me thing itís causing issues. On top of that, it limits measurement of certain features.
    My thought is just to use a vacuum to pull the part into a low-profile locating fixture. More access, and to your point less influence.
    The other advantage is around timing. We have front and back features that arenít necessarily timed to each other, so thereís thoughts around a mechanical clocking mechanism to orient each feature. Thatís a tall order. Iím well aware itís a silly idea, but Iím curious whether anyoneís done it.
    Mar 2005
    Indiana
    6,536
    2346
    2533
    You could certainly make a vacuum fixture that would hold on an O.D. from the side, but locating might be interesting.
  9. #8
    GERMANY
    3,739
    2523
    1538
    A hand sketch showing the part and your proposed fixture would help. Or a photo of your part.
  10. #9
    Nov 2018
    ALAND ISLANDS
    356
    160
    118
    The two flats on either end represent unclocked features, though I clocked them here because it was easier to sketch quickly.
    This is my "I've got 60 seconds" thoughts about what the fixture would look like. The posts would just be old short CMM probes. The rearmost post would be a locator along the axis while the other 4 are essentially V-blocks.
    I found this thing on McMaster Carr: McMaster-Carr
  11. #10
    Feb 2007
    Aberdeen, UK
    4,811
    1781
    2369
    Are your parts non-magnetic?
    A small four-bearing inspection vee block with a magnet in the centre might achieve the same result?
  12. #11
    Nov 2018
    ALAND ISLANDS
    356
    160
    118
    Quote Originally Posted by gregormarwick View Post
    I wish. Copper.
  13. #12
    Nov 2015
    629
    289
    It would be held around the full diameter, but a place I used to work had a test fixture that you dropped a spool into, was clamped, tested, then lifted out. The fixture was set up like a hydraulic tool holder, so the walls just swelled a bit. I don't think that would be able to cover a full 0.002" range, but perhaps it spawns a few new ideas.
  14. #13
    Nov 2018
    ALAND ISLANDS
    356
    160
    118
    Well, the little rubber vacuum cup works. Iím not sure how reliable it would be on a fixture, but itís nice to know it functions.
  15. Likes gregormarwick, ballen liked this post
  16. #14
    Feb 2007
    Aberdeen, UK
    4,811
    1781
    2369
    Well, the little rubber vacuum cup works. I’m not sure how reliable it would be on a fixture, but it’s nice to know it functions.
    This led me to search for UK or European sources for these, and I found this place, they have a lot of variety of these things, the bellow type ones look like the solution to your problem.
    Vacuum Suction Cups | Schmalz
  17. #15
    Nov 2018
    ALAND ISLANDS
    356
    160
    118
    I did end up getting a few with the bellows so itíll pull it into whatever itís locating to. This one is fairly restrictive. Might work well on the end of a robot or something though.
  18. #16
    Sep 2016
    Missouri
    1,240
    1024
    418
    Could you mill a trough 1/4 or 1/2 diameter into a block fitting the side of your part diameter and drill several vacuum ports going to a central port.
    Maybe line the trough with a split piece of tubing [ nylon, Teflon, rubber ] Something with a durometer that gives the surface a texture to help seal against the part
  19. #17
    Oct 2007
    SPAIN
    5,690
    1546
    836
    I think vac will work for your application as it's only CMM pressures.
    But possibly....V block as you say and slide a top "sprung finger" over the top instead of vac?
    Simple fixture with a V and a piece of 1.5mm thick stainless captivated in a slot with a top to stop lifting would do.
  20. #18
    Nov 2018
    ALAND ISLANDS
    356
    160
    118
    Quote Originally Posted by barbter View Post
    Thatís pretty much the fixture they came up with, but Iím really doubting our GRR results lately. Itís a fairly loose fixture, which just comes down to their design, but even perfectly rigid, the groove isnít a very tight tolerance. Hard to make a jaw that keeps it snug.
  21. #19
    Nov 2010
    UNITED KINGDOM
    1,056
    208
    252
    They use suction cups in the packaging and printing industry, that could be a source for different cup styles.
  22. #20
    Jan 2015
    Missouri
    1,631
    237
    1032
    I have a bunch of this cmm fixturing if you are interested in some.
    Don
