Part fixture: Vacuum on a diameter
Results 1 to 15 of 15
    Nov 2018
    ALAND ISLANDS
    341
    155
    117
    Default Part fixture: Vacuum on a diameter
    Hello!
    We do lots of round parts of different shapes and sizes, but they all tend to have a similar .500 +/-.001 OD in one way or another. We've got a few variations on fixtures, but there's always a trade off.
    Is there a method of madness to hold a small OD using a vacuum?
    GERMANY
    3,648
    2427
    1463
    Quote Originally Posted by thunderskunk View Post
    Vacuum provides a pressure of 14.7 pounds per square inch or about 1kg per square centimeter. Your part has such a small area that the "clamping forces" from a vacuum would be about 3 pounds = 1.5kg. That's not nearly enough for any standard machining operations, not even grinding.
    Jan 2005
    The Netherlands
    6,735
    371
    1969
    Quote Originally Posted by ballen View Post
    Unless he applies vacuum on 180į of the the side Then it depend on how long the 0.500" feature is
    But I agree A collet would perform better You could go fancy with a air or hydraulic operated colletcloser
    Peter
    Nov 2018
    ALAND ISLANDS
    341
    155
    117
    To your point, 3# isnít enough, but keep in mind itís just going in a CMM after machining is 100% complete.
    Now that Iím rereading my original post, Iím realizing I didnít actually say this was for a CMM, just posted in metrology, so thatís on me.
  5. Likes ballen liked this post
    Feb 2007
    Aberdeen, UK
    4,615
    1687
    2181
    I'm not really sure how a vacuum would work holding an od. It can neither expand the part nor shrink the fixture, so what would it really achieve? The vacuum itself is not what holds the part on a vacuum plate...
    I assume you're struggling with physical workholding methods distorting the part?
    Nov 2018
    ALAND ISLANDS
    341
    155
    117
    Not quite. Weíve got a few ways we currently hold the parts; if you want to measure the front, you use a datum simulator on the back. If you want to measure the back, you use a v-block on the front. If you want to measure both, weíve got a thin clamp that sort of works, but recent data made me thing itís causing issues. On top of that, it limits measurement of certain features.
    My thought is just to use a vacuum to pull the part into a low-profile locating fixture. More access, and to your point less influence.
    The other advantage is around timing. We have front and back features that arenít necessarily timed to each other, so thereís thoughts around a mechanical clocking mechanism to orient each feature. Thatís a tall order. Iím well aware itís a silly idea, but Iím curious whether anyoneís done it.
    Mar 2005
    Indiana
    6,173
    2166
    2154
    You could certainly make a vacuum fixture that would hold on an O.D. from the side, but locating might be interesting.
  9. #8
    GERMANY
    3,648
    2427
    1463
    A hand sketch showing the part and your proposed fixture would help. Or a photo of your part.
  10. #9
    Nov 2018
    ALAND ISLANDS
    341
    155
    117
    The two flats on either end represent unclocked features, though I clocked them here because it was easier to sketch quickly.
    This is my "I've got 60 seconds" thoughts about what the fixture would look like. The posts would just be old short CMM probes. The rearmost post would be a locator along the axis while the other 4 are essentially V-blocks.
    I found this thing on McMaster Carr: McMaster-Carr
  11. #10
    Feb 2007
    Aberdeen, UK
    4,615
    1687
    2181
    Are your parts non-magnetic?
    A small four-bearing inspection vee block with a magnet in the centre might achieve the same result?
  12. #11
    Nov 2018
    ALAND ISLANDS
    341
    155
    117
    Quote Originally Posted by gregormarwick View Post
    I wish. Copper.
  13. #12
    Nov 2015
    582
    250
    It would be held around the full diameter, but a place I used to work had a test fixture that you dropped a spool into, was clamped, tested, then lifted out. The fixture was set up like a hydraulic tool holder, so the walls just swelled a bit. I don't think that would be able to cover a full 0.002" range, but perhaps it spawns a few new ideas.
  14. #13
    Nov 2018
    ALAND ISLANDS
    341
    155
    117
    Well, the little rubber vacuum cup works. Iím not sure how reliable it would be on a fixture, but itís nice to know it functions.
  15. Likes gregormarwick, ballen liked this post
  16. #14
    Feb 2007
    Aberdeen, UK
    4,615
    1687
    2181
    Well, the little rubber vacuum cup works. I’m not sure how reliable it would be on a fixture, but it’s nice to know it functions.
    This led me to search for UK or European sources for these, and I found this place, they have a lot of variety of these things, the bellow type ones look like the solution to your problem.
    Vacuum Suction Cups | Schmalz
  17. #15
    Nov 2018
    ALAND ISLANDS
    341
    155
    117
    I did end up getting a few with the bellows so itíll pull it into whatever itís locating to. This one is fairly restrictive. Might work well on the end of a robot or something though.
