Pocket micrometer or equiv
Results 1 to 15 of 15
    Sep 2005
    Northern California
    860
    108
    Default Pocket micrometer or equiv
    Out wandering the shop floor in a factory that builds electronics, it would be handy to have an EDC "pocket micrometer or equiv" And it's not like I'm lacking the usual full size suspects from TESA and Mitutoyo
    Tried one of those Horrible Freight 4" digital calipers with the jaws amputated back for more pocket friendly carry but the accuracy was always suspect generally poor.
    The little 1/2" Starrett 232 micrometer isn't a one hand friendly tool
    A full size 1" / 25mm mic is a lot of bulk for a pocket.
    Ideal would be 15mm capacity 0.01mm resolution and accuracy, sport shirt or watch pocket carry.
    Anyone else this obsessive? Found something you can live with as a daily carry
    Cyclotronguy
    Mar 2005
    Indiana
    4,654
    1205
    1092
    Feb 2019
    New York
    116
    76
    Mic/Caliper holster
    Jan 2002
    West Coast, USA
    8,299
    561
    5792
    My guess is that a higher quality 4" digital caliper in a leather sleeve is about as good as it gets, if you need digital / metric / US measurements. Cut to 2" or so if need be.
    MItutoyo makes a super accuracy slide micrometer, but it's as large as any other 1" digital mic.
    If your work is all either metric or US, I'd think a 1/2" or 15mm mic would barely slow someone down preferring one hand use. There are some beautifully-made examples from the past. Using two hands -- might add ten seconds to a day. Hunting up a mic or not have the measurement you should have taken -- might add ten minutes to a day?
    Do a agree someone should make a pocket-friendly tool. For me it would be caliper-like, go to 50-60mm, be US/metric, and find a way to still do depth and inside measurements; maybe with a sort of flip-away or slide-away guard over the ID points? I've seen scalpels with slide-away covers that worked OK. Let me know if you find one.
    There's a reason so many ran around with a 6" rule, reading to hundredths, and stashed in a pocket protector. And a reason for those belt-carry mic holsters. These days, thousandths and tenths are more commonly needed; especially, I'd guess, if your name is something like Cyclotronguy.
    Sep 2005
    Northern California
    860
    108
    I don't care if it measures imperial or metric, or if it's old school vernier.... I can do the math.
    Pete M: as indicated I had a Horrible Freight 4" POS digital caliper that I cut the jaws back on... so there was no poky-bits in pocket. (wife hates it when I poke holes in shirts / slacks) Not a bad implementation... just the basic platform was flawed.
    The Starrett 1/2 mic looks great in pictures, (0.0001" / 0.002mm resolution) .... but it's quite a bit smaller in real life; to the point that it's almost a three handed affair; two for the mic and one for the part.
    I saw a photo of the Fowler "Snap-cal" and that might be just the ticket.
    Appreciate all the reply's Going to look into the Fowler piece.
    Cheers
    Nov 2014
    Florida
    4,336
    1680
    2051
    Quote Originally Posted by Cyclotronguy View Post
    Cheers
    ?? You don't use one hand for a 1" (non digital) mic? I learned to hold them with my ring finger looped thru the 'c' part, then use thumb and index finger to operate the barrel.
  7. Likes CalG, Winterfalke liked this post
    Feb 2019
    New York
    116
    76
    he means 0-1/2" I know my fat fingers wouldn't fit in one
  9. #8
    Feb 2004
    peekskill, NY
    25,098
    5007
    Respectfully disgree. Works good for me, it's my go-to for on-the-move jobs.
  10. Likes CalG liked this post
  11. #9
    Dec 2005
    Wisconsin
    929
    13
    132
    so are you looking for a mic or a caliper?
    Here is a pocket friendly mic. (can seam micrometer)
    208MZ Stainless Steel Can Seam Micrometer
    Dave
  12. #10
    May 2017
    FINLAND
    2,109
    570
    978
    thickness gauge sort of?
    Quick-Mini Series 700
  13. #11
    Jun 2011
    200
    27
    69
    Funny you should mention! I’m an engineer and a home shop machinist. At work, I visit the factory daily. And it happens that I need to measure stuff while I’m there. So I’ve begun to carry an ancient Starrett 436 mic in my back pocket. It’s very smooth and round and compact, doesn’t catch on stuff. I like Starrett’s markings. I think they are easy to read, even without my reading glasses.
    At home I use a digital Mitutoyo. I’d like to have that at work, but if it got legs or I sat on it, I’d be sad. I think I paid less than $30 for my 436.
  14. #12
    Nov 2015
    386
    142
    Some will really frown on this as abusing a measurement tool, but if your fingers don't fit in the pinky of a Starret 232 I'll bet you could drill a 3 to 4 mm hole at the right spot in the anvil, install a key ring, and loop your pinky in that. Might lose some accuracy, but given that a pair of calipers with clipped tips was ok, this might be too.
    Personally I'd just get pants with a big enough pocket to hold a 0-1" mic.
  15. #13
    May 2002
    South Central PA
    13,829
    2403
    3644
    I bought one of these from Ebay for ~ $60 thinking it would serve in my apron pocket better than a mic or 6" caliper. So far i haven't warmed up to it because I try to hold it like a 6'" caliper and I can't. It does measure just fine, I trust it to .001 but I haven't got the feel for it in my hand just yet - I have to pull it closed instead of push it like a normal caliper, and I think it would go better in my left hand. YMMV.
  16. #14
    Jun 2008
    Akron, Ohio
    67
    19
    I have a Starrett #223 paper gage mic.
    Obviously not a go-to for measuring everything. More to the point, the finger ring works well, I'm surprised this isn't more common on smaller mics. Makes it a lot easier to 1-hand.
    I've never seen a factory 1/2" standard mic with the finger ring. But IIRC Starrett and Lufkin showed the ring as optional.
  17. Likes Rex TX, Mud liked this post
  18. #15
    Virginia
    30,504
    7561
    9524
    Cyclotronguy
    Surely.
    Competent staff who knew their jobs well and were aware I EXPECTED them to do and had seen to it they had such metrology goods as THEY needed to do so.
    What's yer goal?
    Guy who supervises professional BUTCHERS doesn't get "in their face" on the job to show-off a cotton-picking miniature Swiss Army knife as fits in the crotch-pouch of his jockey SHORTS does he?
    Not unless he figures his glutes and thighs might TASTE better to the customer than USDA Choice beef, he does not!
