Problem with Starrett 721 digital caliper
Likes Likes:  0
Results 1 to 17 of 17
    Dec 2014
    83
    180
    22
    Default Problem with Starrett 721 digital caliper
    I received a Starrett #721 digital caliper a few years ago as a gift. I never used them and they have been sitting inside a sealed plastic container in a drawer ever since. I opened the case and took them out this morning, When I slid the battery cover plate to activate the unit, only the bottom half of the digits appeared. I went to Radio Shack and got a new set of batteries and the results are the same.
    The unit appears to be measuring but the upper half of the screen only appears when I press and hold the "hold" button.
    Am I doing something wrong?
    I'm wondering if repair would cost more than replacement?
    Thank you.
    Bob
    Aug 2013
    NY
    2,298
    984
    800
    Shot LCD screen, or the lower half of the screen might not be getting power form the main board, send it back to starrett.
    Jun 2012
    Eastern PA
    1,038
    307
    468
    Most LCD screens are not hard-wired or soldered to the circuit boards. Instead, there is a laminated strip of plastic with conductors in it, that us sandwiched between contacts on the display, and contacts on the circuit board.
    Usually, there is one strip at the top of the display, and one at the bottom, but sometimes there is only one.
    You may be able to open the caliper up and clean off the contacts on either the circuit board or the display board, it sounds like yours is just dirty, and that's why pushing on a button causes the display to work.
    Dec 2014
    83
    180
    22
    Thanks very much for your speedy responses.
    I just sent an e-mail to Starrett and will see about sending the caliper in.
    I'm wondering if I should avoid electronic measuring tools in the future.
    With everything I am reading, I am wondering if I should avoid Starrett? When I was in school, Starrett was the brand to have.
    Thanks again.
    Bob
    Sep 2010
    South Of Lake Superior, USA
    148
    19
    If you decide to try to fix the problem yourself, be advised the problem is probably faulty connections between the circuit board and the glass LCD display. The connection between the two is in the form of a (usually) silicon rubber strip with built in conductive channels. These things are called Zebra Strips or elastomeric connectors and the problem can sometimes be cured by dis-assembly, a scrupulous cleaning and reassembly. Note the "sometimes"!
    Google searches will turn up many useful tips.
    Regards
    Aug 2013
    NY
    2,298
    984
    800
    Quote Originally Posted by MARVINGARDENS View Post
    Thanks again.
    Bob
    I've used my cheepie digital caliper for years....thousands of measurements. I hate to say this around here, but I trust it as fat as calipers go. Never given me a false reading, and always within a half thou for under 1" dimensions. Don't have a over 1" mike to back up readings any higher than that.
    If my cheapie is good, your Starrett is better, you just got a lemon.
    Sep 2010
    148
    19
    You may be able to confirm that the problem is with the Zebra strips by pressing down along the top or bottom edge of the display. If any portion of the display returns to normal it means the additional pressure has improved or re-established electrical contact. If pressure applied along the entire length of either or both the upper and lower edges of the exposed LCD returns the entire display, a thin paper shim between the display and its bezel might be a jerry-rigged fix.
    This all assumes the connection between the display LCD and circuit board is made using Zebra strips - which is a fairly safe assumption considering it's the cheapest way to do it. Those little Zebra strips... Thermal Interface Materials from Fujipoly America | Design Guidelines - Connectors ...are only about 10¢ apiece but from what I've read are nearly impossible to get (unless you order 1,000 of them).
    Regards
    May 2009
    Canandaigua, NY, USA
    3,017
    151
    1381
    I'm not a fan of early Starrett digital stuff. More recent seems better. I had #722 and fixed them (there's a page on my site), but they still tended to eat batteries at ten times the rate of Mitutoyo, so I got rid of them.
    Dec 2014
    83
    180
    22
    I contacted Starrett and received an e-mail reply that my calipers were obsolete and no longer supported.
    They did say they offered these calipers as replacements.
    799A-6/150 $102.90
    OR
    798B-6/150 $162.40
    The 799A price is a few dollars less than I could buy a new set for from Amazon. The 798B about sixty dollars less.
    Not exactly free replacements but I can't blame Starrett for me leaving an unopened package in a drawer for a few years.
    I shipped mine this morning and they are supposed to contact me when they examine them.
    I'll make a decision then. I am leaning towards just picking up a used set of dial calipers.
    Thanks.
    Bob
    Feb 2014
    FL
    3,433
    11710
    3936
    Just buy a set of digital Mitutoyos and be done with it.
  11. #11
    Jun 2014
    United States
    35
    Mitutoyo digimatic absolute are excellent calipers, the best as far I can see. You have to turn them off though or battery will die.
    And DON'T leave the battery in if you're not using it for while. Starrett makes great tools but their electronic tools....?
  12. #12
    Apr 2020
    CANADA
    Ontario
    I had a similar problem with my Starrett 721 caliper, it simply just stopped working. Contacted Starrett, it is no longer repairable and they offered me a new one at basically the same price I can buy it on Amazon. BTW, the replacement ones are made in China. I purchased a new Mitutoyo Dial caliper, works great, no batteries to replace! It was difficult to toss the Starrett unit in the metal bin, but I had no other option.
  13. #13
    Nov 2007
    marysville ohio
    9,878
    2819
    6584
    Thanks again.
    Bob
    Just avoid Starrett electronic stuff. Mitutoyo is way better. I have 20+ year old Mits as well as brand new coolant proof ones. Batteries last 10x as long, and if they do die send them back to mitutoyo and you get a new pair for half price.
  14. #14
    May 2010
    DENMARK
    3,724
    4080
    12731
    Quote Originally Posted by dwarren48 View Post
    I hate to break the news but as good as all digital calipers are now made in China. The top brand names do monitor what gets made for them. Even a good bit of Mitutoyo electronics get made in China but they have a patent that prevents blatant copying and Mitutoyo are big enough to have the clout to do something re copies.
    I don't always get the battery "problem". A battery costs around $2 to $3 and if an extra is kept in a refrigerator (not a freezer) then - no problem. The main types of digital caliper batteries are 1½v LR and SR (SR being better than LR) and CR3012 (3v).
  15. #15
    Feb 2004
    peekskill, NY
    25,322
    5170
    Bob
    In a word, yes.
    Two more words: Mitutoyo Digimatic.
    'nuf said.
  16. #16
    May 2010
    DENMARK
    3,724
    4080
    12731
    Quote Originally Posted by jim rozen View Post
    Mitutoyo Digimatic.
    What does a Mitutoyo Digimatic cost in the USA compared to for example a Sylvac or Tesa?
    As sold by a reputable dealer.
  17. #17
    GERMANY
    3,040
    1975
    1114
    I suggest you get a Mitutoyo Absolute Digimatic Caliper, 6" long. If you shop around you can get them new for around $100. If you take good care of it and follow the instructions (about exact type) when replacing batteries, it will last many years and be accurate for that entire time.
