Radius Measurement at Bottom of Blind Bore
Likes Likes:  0
Results 1 to 5 of 5
    May 2020
    Smile Radius Measurement at Bottom of Blind Bore
    Hi Guys,
    Been using this site as a resource for years and just decided to sign up with a query of my own. Also looking forward to lending some input where I may be able to help out.
    Jumping into it - I've been racking my head on how to go about measuring the following:
    Characteristic:
    Feature: .030" +/-.010" internal radius, 360°
    Location: Bottom of a 1.4" diameter, 22" long blind bore
    Material: AMS 5648 Steel, 32 Ra Surface Finish
    The customer has indicated this is a flight safety characteristic, therefore:
    Quality Requirements:
    -100% Inspection, each part
    -1/10 tolerance resolution minimum on gauging equipment
    -Capable to pass gauge R&R 20% or better
    This is a high volume for us, so inspection turn around time for this particular feature should be only a couple of minutes per part (setup time of ~10 minutes would be acceptable).
    Unacceptable methods:
    -CMM (our probe tips/extensions would not be capable)
    -Mold/Comparator (we use a 2 part mold and optical comparator on other features, but wouldn't be timely enough for this)
    -Contourograph (Contracer) (we have one, but likely wont reach, and setup plus 360° measurement, even if just 8 places, would take too long)
    -A Go/NoGo setup. Must be able to produce variable data.
    Potentials:
    -Laser/Direct Optical: Possible, but cost may be a factor.
    -Light Projection with Direct Visual Comparator: I saw a post where this was recommended as a solution to a guy working with a busing, but not sure how accurately this could be setup.
    Hope someone here has a good idea - or at least finds the brain exercise that comes with this entertaining! Thanks for any thoughts on this one.
    Oct 2010
    Oregon
    5,291
    4743
    1939
    Talk to the folks who make air gaging equipment. They can probably do a custom head for that feature, and putting the head on the end of a 22+" shaft would be no trouble at all.
    Jun 2012
    Michigan
    11,300
    3870
    3990
    May 2020
    Quote Originally Posted by sfriedberg View Post
    Thanks! We use air gauges here and there but couldn’t find anything advertised for bore radii. Might be a custom job, but good to know they’re capable. I’ll look into quotes!
    May 2020
    Quote Originally Posted by michiganbuck View Post
    Thanks! I did run across that company in my search, but must have missed that product/tech. Will definitely look into further!
