StrawberryBoi
- Aug 31, 2021
I have a side project relevant to machine building and I just need purely linear range finding, but down to something like the accuracy of a C0 screw at 10µm/m (including repeatability), with a range of at least 1m. Response time on the measurement could be as slow as 1s, though faster is of course always better. I can perform calibrations 'lights-out' over a solid week if need be, so settling times of 1s would still allow sub-micron steps if even measurable.
I'm looking around and it seems that at short distances, laser diodes with built in emission regulators can be used for this with averaging and get down to micron or sub-micron.
This isn't for varied part metrology, I'm looking to do calibration on a clean/new linear motion component and so I could provide a controlled environment for it. I've worked with products in the micron accuracy range before on the design and manufacturing side before as an ME, however I've not been responsible for developing or implementing measurement methods. I know at the workplace I did these designs for we used a CMM that had a 2µm accurate repeatability for $$$$, but that was a full 3D scanning probe system. I just need range finding so I can calibrate from start to finish on a controlled linear motion. I can even make the target, so I can ensure a minimum level of runout on the rangefinder if it can have a focused target, say a small mark or feature on the target with alignment set at 1000mm, then motion profile measured across the full range stop to stop.
In a real machine environment this would be a terrible idea, but in a clean environ with time for settling of vibration, I feel like there should be a (relatively) low cost solution.
Any help is GREATLY appreciated.
