reggie_obe
- Jul 11, 2004
- Reddington, N.J., U.S.A.
Acquired this surface plate, it's a cast iron B&S 10x15.
Someone apparently used it as an anvil or for peening or punching out something. It's not cracked and I'd like to restore it's flatness. Should I:
1) lightly surface grind it, then scrape it flat
2) stone it and then scrape it flat
3) scrape it flat
4) check it for raised burrs/ridges/etc., stone those off, blue a known "good" granite plate, print this plate against it, proceed with 1, 2 or 3 depending on the result
3) scrape it flat
