Does anyone know the Dimension Standards for Measuring size?
Say you have a 1" flat bar 6" long with a tolerance of plus or minus .002 on the thickness. The bar measures 1" all the way across until the last 1/4". It then starts to taper off to being .997 at the very last measurable point. Is this then out of tolerance? Is there some sort of standard that you actually measure this distance from 2 "planes"?
