Crowndroyal
- Jun 3, 2019
- Sarnia
Not sure if my title is accurate enough bit here it goes, I have had many jobs over the years in high production parts and almost every one of those jobs there was always a software program where we could see what dimensions to check and enter the dimension results which would then either tell you via some sort of text or visual format if it was in tolerance.
( green yellow red ) or give you text format of ( low med high ) and so on.
The results are almost on networks so that QC can get live results or a pdf etc format of results sent to them at a particular time.
These softwares also record speeds and feeds being used tool ware counters etc etc.
I have tried using Google to find these typea of software but have been unsuccessful.
I am assuming im using the wrong wording.
Is anyone able to give advice on these types of software ?
