Sony DRO nightmare Hopeless?
Results 1 to 10 of 10
    Apr 2018
    Colorado
    5
    Default Sony DRO nightmare Hopeless?
    Have a DRO on my mill. Sony LH-200 with SR-2711 scales. Worked.
    Display is getting more and more flakey. Bought a LH-20 display
    that works great. Scales plug right in.
    But.... I get 0.778" displayed inch per real inch. Scale
    factor is wrong.
    Is there any hope? Bill Hale Loveland CO
    Mar 2009
    Eureka, CA
    3,437
    628
    1101
    Bill,
    Welcome to the forum. I recently had my Sony display fail and during the search for a repair answer I talked to the horses mouth. Give these folks a try, they're Sony, with a new improved name!
    Stuart
    Magnescale Americas
    1 Technology Drive, Suite F217, Irvine, CA 92618 USA
    TEL:+1(949)727-4017
    FAX:+1(949)727-4047 E-mail: [email protected]
    Jan 2005
    The Netherlands
    5,452
    232
    1273
    Is there a linear compensation active on the display
    On a LH10 if you put the power on then SONY is followed by the number of the linear compensation
    Peter
    Apr 2018
    Colorado
    5
    Quote Originally Posted by Peter from Holland View Post
    Peter
    There is but its range is extremely limited like a few thousandths. bh
    Mar 2009
    Eureka, CA
    3,437
    628
    1101
    I have no idea if your Sony display is the same as the old one I had..a LH-42, but on that unit there is a parameter to set scaling. It's different from linear compensation. The program function display is "SCALING".
    Stuart
    May 2004
    Owensboro, KY
    324
    55
    Default Lh-200
    Quote Originally Posted by Bill Hale View Post
    factor is wrong.
    Did you try taking the case off the original display and re-seating any and all connectors, circuit boards and any socket mounted ic's? That took care of the flaky issues on mine. Sometimes the connectors and plugins get a little corroded.
    Charles
    Apr 2018
    Colorado
    5
    Quote Originally Posted by fixitup View Post
    Charles
    I did exactly this because we know failures are usually connectors, etc. No joy.
    It acts like the clock has failed. I see a 4 mhz crystal on the power board. With a schematic I could probably fix it. Crystals have lousy reliability too.
    Thanks for the help. Bill Hale
    Apr 2018
    Colorado
    5
    Quote Originally Posted by atomarc View Post
    Bill,
    Stuart
    Magnescale Americas
    TEL:+1(949)727-4017
    For archival purposes, I emailed these guys and got a quick reply. The LM-20 is designed
    for metric scales. Won't work with the SR-2711 english scales. Interestingly, when I
    set the LM-20 to METRIC, it reads 20.000 per actual inch which is almost usable. Unfortunately
    changing it to diameter goes the wrong way, making it 40.000 per inch.
    BH
    Nov 2005
    Maryland
    8,522
    744
    1069
    Huh ? ? ?
    Crystals are quartz that has been in the environment for eons.
    I use crystals that were made before WWII with no issues.
    - Leigh
    Nov 2008
    Madera county california usa
    2,176
    19
    520
    That crystal only runs the machine and effects how fast the electronics run.
    All do age and the speed changes a bit and in radio we need to "tune" them but in this application it likely does not matter a bit
    It will be running if "working" and dead if not.
    Since running crystal good.
    All scales have a resolution or bits per distance and the display simply counts them and converts to display them.
    Your scales may not be compatible with your display unless there is a setting as already posted.
    Focus your effort only on that task as the "box" seems to be just fine and doing exactly what it is designed to do .
    Look for configuration settings to allow scales to be configured but it also may only work with certian ones...no clue there but others may already have been there.
    Google is usual help here...Search exact and full model number plus word "configuration" or "setup manual"
    Good luck!
    Sent from my SAMSUNG-SGH-I337Z using Tapatalk
