SPI 0-18” Digital Height Gage reading “Err” going up and down
Results 1 to 5 of 5
    Dec 2016
    Indiana
    9
    Default SPI 0-18” Digital Height Gage reading “Err” going up and down
    As the title states. This problem happens when I crank the handle up at almost any speed, faster seems worse. I get Err and it will go away if I continue up or down. Does it sporadically doesn’t appear to be in the same spot. Any thoughts on DIY fix or how to verify what is causing it?
    May 2010
    DENMARK
    3,606
    4060
    12678
    My first question is "How old is it?"
    Second question "When did it start doing that?"
    Mar 2019
    UNITED KINGDOM
    187
    33
    My SPI calliper shows ERR when the battery is inserted awkwardly, so it could be a lose connection?
    I may be wrong but does it show ERR-1 or ERR2, or just ERR? I think they have different meanings.
    Oct 2007
    SPAIN
    3,777
    2171
    1444
    Quote Originally Posted by _Kodak_ View Post
    So if you go up/down really slow, it's okay?
    Nov 2007
    Orlando, FL
    406
    882
    159
    It may mean that there's some contamination on the surface that is "read" by the electronics. Usually, a good wipedown with some alcohol will clean the oil/coolant/spooge, or whatever's on it.
  6. Likes barbter liked this post
