Surface gage / meter - what works?
Results 1 to 4 of 4
    Jan 2005
    Houston
    6,507
    972
    3395
    Default Surface gage / meter - what works?
    Most engines use head gaskets for which the gasket makers specify a surface finish of 50Ra or better. Some gaskets are OK for 80Ra or better. This is for both cast iron and aluminum surfaces.
    So....in looking at Ebay I see two basic types of meter / gages....the sort that looks like a dial indicator and the type that costs more and is more of a 'black box'.
    Does the black box type work better or is it just fancier? Do either of these accurately measure finishes in the 50Ra range? I looked at the specs and it wasn't readily apparent to me.
    Thanks!s-l1600-profile.jpgdefelsko-positector-spg3-e-3-advanced-body-surface-profile-gage-810257032392-ebay.jpg
    Nov 2014
    Florida
    5,669
    2251
    2826
    I've never seen any like that, but have used one of these -
    Test, Measurement & Inspection | Hardness Testers, Durometers & Surface Testing | Mahr Federal 2191800 Pocket Surf IV Portable Surface Roughness Gage EGH-1019 10 MicronM Radius | B580945 - GLOBALindustrial.com
    I can't see a handheld gage being accurate, but if 50Ra is the best you'll need, maybe?
    Also might want to try this, unless you need to get an actual number.
    https://www.mscdirect.com/browse/tnp...BoC8JMQAvD_BwE
    edit: that ^ one is for planing and shaping cutting methods, but they make them that have samples of side milling, face milling, turning, etc.
    Jan 2012
    Southwest
    1,111
    118
    299
    Those gauges are inappropriate. They take single readings of the height above or below an average. What you need is a surface profilometer, AKA surface roughness gauge. Those drag the equivalent of a phonograph needle (if you remember what those are) a fixed distance across the item to be measured and from the up/down motion of that needle calculate either the peak-valley height or rms roughness, as selected by the operator.
  4. Likes GregSY liked this post
    Jan 2005
    Houston
    6,507
    972
    3395
    Thanks to both of you....I'll look for a profilometer.
