surface plate reconditioning
Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Feb 2003
    wind gap pa
    160
    6
    Default surface plate reconditioning
    i have a 3' by 4' plate that needs at least a sixteenth removed. Local metrology companies do not have the equipment to do this. I was thinking of approaching a granite counter top mfg to do the initial removal of material then have the finishing done by a service. What do you guys think of this approach? Or do any of you know of a firm that has that capability in the north east Pennsylvania area or north New Jersey.
  2. Likes SalemRule liked this post
  3. #2
    Nov 2007
    Orlando, FL
    402
    872
    154
    If I may ask, how did you determine that 1/16" needs to be removed? That is a MASSIVE amount of material to be removed, in terms of a surface plate. Is it damaged in some way? One of the advantages of granite is that, if something is dropped on it, the granite will chip out, and not leave a raised area, whereas a cast iron surface plate will leave a "bump" of material above the surrounding surface, in addition to the "dent" below the surrounding surface. The raised portion MUST be removed.
    I think the cost of removing that much material, in addition to having the surface plate re-finished and calibrated may make it more economical to go with a new plate. Your mileage my vary...
  4. Likes SalemRule liked this post
  5. #3
    Dec 2004
    uk
    14,057
    4552
    6705
    I could not do flat much better than 1/16" with a coarse disc but with a 5" wet grinder takeing 1/16" of a 3x4 granite is not going to even take a hour, Diamond cuts granite pretty dang quick. With just a bit of practice, the finer discs let you make a surprisingly flat surface too.
    One word of warning though, most counter top places will not be set up to handle such a lump of stone and a fair few have no sheet polishing at all and just buy in pre polished sheet then and only then cut and hand polish the edges.
    If you can ID the high spots, then a copper bond wheel around the 200 grit range or finer would be able to get you down into hand lapping back to tolerance rage pretty easily. Its a very wet and messy process though and you need the measuring gear to ID the high spots as you go, cost wise it would make way more sense to go buy a good plate than do this. But honestly if you had the mesuring gear and were local, i would be up for trying on a warm day, Simply mark the high spots and take em off just like scrapeing. Get up into the 1000 grit pads and your not going to remove much more than a few tenths a minute. Realy depends on what you can measure too and how near you want it prior to start the true hand work, but would be fun to try!
  6. Likes ballen, SalemRule liked this post
  7. #4
    Feb 2003
    wind gap pa
    160
    6
    Some one really misused this plate. There are many little chips from the surface, also when you run your hand across it it feels rough. A 1/16th is best guess based on a visual of the dings in it.
  8. #5
    Jul 2007
    UNITED KINGDOM
    4,889
    2636
    2382
    It may be more economical to keep an eye on ebay/craigslist/whatever for one in a better condition. OK, shipping distance is a big problem, but it does take man-hours (=$) to lap a wrecked plate down to some semblance to flatness. If the counter-top/grave stone shops in the area can grind 3'x4' stones, then you should be able to get within a few thou. At which point a surface plate re-surfacing/calibrating company should be happy to take your money.
  9. Likes SalemRule liked this post
  10. #6
    Jun 2016
    New York
    1,638
    958
    757
    Quote Originally Posted by roll maker View Post
    Not worth it. There are plenty of surface plates in our area that turn up at auction, so either work around the dings, or get another one, unless you have more time than brains, (something I have been guilty of so, ok I am a hypocrite!)
  11. #7
    Jun 2012
    Michigan
    10,210
    3462
    3646
    A Blanchard shop can grind it near flat..but likely charge 2 hours for the job..Yes I'm just guessing.
    You don't need to bottom every ding full depth to make it useful.
  12. #8
    Feb 2003
    wind gap pa
    160
    6
    Additional question. How much is the maximum material that a calibration service can remove by lapping without the labor getting out of hand.
  13. #9
    Feb 2011
    2,280
    1720
    973
    Went through all this a few months back. IMO any granite plate smaller than 3' in any direction with visible damage is an expendable piece. Bigger will often be worth the effort. From my research, most shops are less concerned with what needs to come off and more with what tolerance (B, A, AA) you want it to be. That and the size are what makes up their cost. We looked at resurfacing a 3'x6' plate to A specs. Was about $1000.
  14. #10
    Feb 2011
    Washington
    25
    if there are dings, small divots in your rock...it does not necessarily mean it's not flat or flat enough. any kind of fixturing or height gages, etc.. would straddle or simply cover those dings and would be supported by the material around those defects, right? but if you are checking larger parts and need to satisfy tight tolerances using most of the rock at the same time...then yeah, it might be a problem.
    Does any work you do require that your rock is "certified" by a calibration service? does it need to be laboratory grade (AA)? inpsection grade (A) or even shop grade (B)?
    We have a large rock that has some nasty looking dings in it, but it still just barely not ideal, but that'll do until we can have it resurfaced next go around on our calibration schedule.
    I agree with the other posters that resurfacing is expensive and likely not worth it.
    Our cal service did tell us resurfacing our two small rocks was not worth it if we needed to do it. And one of those is a 3'x4' or close to it. so if you think your rock really is too beat up, get a new one or a newer used one.
  15. #11
    Feb 2003
    wind gap pa
    160
    6
    Grade B would be adequate. I would just like to know we have a good larger surface when needed.
  16. Likes SalemRule liked this post
  17. #12
    Apr 2019
    Arkansas
    49
    5
    20
    If you can measure the errors accurately, then hand lapping with silicon carbide (wet or dry) sandpaper will remove material *very* quickly. Face off some round flat plates of various diameters and glue a piece of silicon carbide paper to it using something like F77 spray contact adhesive.
    I recently flattened a rough and worn Ouachita stone in about 15 minutes by doing figure 8s on a piece of 100 grit paper which I wet on both sides and placed an a 9 x 12 surface plate. And I was using worn sandpaper as I could not find any locally. Fresh 80 grit paper would have done it in 10 minutes.
    There are two issues you have to pay attention to. Measuring the surface flatness and dealing with heating from the lapping. Submerging the plate in water while lapping would probably take care of most of the heating problem.
  18. #13
    Aug 2007
    Northern CA
    1,088
    67
    146
    And here I can't give away a good one 3' x 5' as best I can remember, do you want to make a road trip?
  19. #14
    Jun 2011
    193
    27
    68
    There is a company in Lititz called Garber Metrology whose website says they recondition surface plates. I have no experience with them, but I'm looking for a similar service.
    If you contact them, will you PM me and tell me what they say? My biggest plate is 2X3. I can lift it into my pick up with one of my kids and take it. I also have a Starrett pink 12X18" I'd like recal'd.
    I've seen youtube videos from the west coast of calibration teams going to guys shops and reconditioning a bunch of plates in one day. If that service were available, maybe a bunch of us could travel to bring down the cost per plate of a house call.
    I agree with others here - no reason to remove a 1/16 from any surface plate. They fill deep nicks with epoxy, I think. You really just need all the high spots to lie in a plane. Nicks don't really matter to the calibration, I don't think.
    Fazzio's and Cook's machine, both in south jersey, have large stones pretty cheap just sitting outside. If you can transport them, I'm sure you could find a decent stone at either location. The trick is the reconditioning/calibration. I think there is also a place in north jersey that does calibration that might be closer to you.
  20. #15
    Aug 2018
    Ohio
    29
    11
    9
    Starrett Webber actually doesn't charge that much to recondition and calibrate granite.
    It's the shipping that can make it not worth doing.
  21. #16
    Jul 2018
    Massachusetts
    268
    604
    91
    How about a Gravestone / Monument Company ?
    Those places are pretty much everywhere.
  22. #17
    Jun 2011
    193
    27
    68
    Quote Originally Posted by SalemRule View Post
    That’s a joke, right? Is that some inside joke here that I don’t know?
    This is what I’m thinking about:
    YouTube
  23. #18
    Jul 2018
    Massachusetts
    268
    604
    91
    Quote Originally Posted by AdamC View Post
    YouTube
    Why a joke ?
    The raw material is the same.
    The machinery is the same.
    The polish is the same.
    You see a Grave Stone - I also see a Surface Plate.
    I'd be surprised if Monument Manufacturers don't even have a set of tolerances for flatness, smoothness, etc.
  24. #19
    Jun 2011
    193
    27
    68
    Did you watch the video? Is that how grave stones are made near you? Same tools? Really? Autocollimator? Stones in the video could be flatter than 75microns. That’s .000075”
  25. #20
    Apr 2013
    Damascus, MD
    1,477
    4238
    846
    Adam,
    If I recall correctly, in the video they say that they fixed plated a few thousands off.
    I don't expect many graveyard stones to be flatter than within 10-15 thousands. But, on the other side, it should be as simple as visiting a stone-maker carrying w knife-edge straightedge and, perhaps, some feeler gages. you could likely take care of removing the worst imperfections before having professionals doing the finishing job.
    The problem that I see, however, is that most of the gravestones won't be thick enough for making a good grade large surface plate.
    Paolo
