Vernon Tuck
Stainless
- Oct 26, 2008
- Brenham, Texas
Folks,
I am thinking about acquiring a surface plate. However, as will soon become apparent, I am not a machinist. I will explain my perceived need in hopes that y'all will be kind enough to educate me.
Here's some background:
First, we are motor heads. We own dozens of old VWs and Mercedes Benzes, engines and components. Some of the cars are runners. Others are parts vehicles. These represent my lifetime collection of vehicles.
Second, my wife and our older son, are newly minted apprentice machinists. They just graduated from a one year, rather comprehensive manual machinist course at a Houston, Texas community college (Lone Star).
Third, we now have the makings of a rudimentary little machine shop. This is not to say that we have commercial aspirations but it's also not to say that we don't. At present we have a South Bend 10L tool room lathe and two manual milling machines.
I mention all of this to explain that we have both short term and long term aspirations. In the short term I need to inspect a VW diesel engine head in order to determine if it has excessive warpage. I recently bought an unfinished project from a fellow consisting of an '81 VW rabbit diesel into which he had retrofitted a completely rebuilt engine and transmission. The machine shop rebuilt the engine and head but the previous owner himself installed the head. I bought the car from him before he ever started it.
After we got the car and tied up the loose ends, we got it started. Long story short the car overheated for (at that time) unknown reasons. We NOW know that the fellow put the head gasket in upside down. The engine did not PEG in the red but it got pretty hot during a test run. Those engines (aluminum heads) are very unforgiving of overheating. Hence, I need to remove the head, inspect it, and (knock on wood) re-install it with a new head gasket.
I'm very unclear on at least three points: First, it would be good to know what grade of surface plate I need for this kind of work. Second, I would appreciate knowing what the best and most versatile size would be for a tiny shop such as ours. Not only is price an issue so is available space.
Third, I assume that when inspecting a cylinder head on a surface plate that the plate has to be slightly bigger than the head. Is this correct? If so, I would say that the biggest size I would need would be one that's big enough to inspect the head from a Cummins B, 12 valve, 6 cylinder engine such as used in Dodge trucks until 1998.
Finally, I would appreciate receiving some advice on how to determine a used plate is a good one, and how much I might reasonably expect to pay.
In the short term I'd like to inspect several cylinder heads. In the long term, my wife and son will hopefully evolve into machinists and become competent to do our own machine work - at least surfacing heads.
I will genuinely appreciate your help. I hope the metrology forum is the right place for this question.
Sincere regards and many thanks.
Vernon
Vernon
