Test Indicator vs Co-Ax Indicator Accuracy ?
Results 1 to 10 of 10
    Jan 2011
    Kansas
    738
    50
    58
    Default Test Indicator vs Co-Ax Indicator Accuracy ?
    I've been trying to wrap my head around this question. This comes up when we have one of our CNC lathes that gets bumped or crashed and we are dialing in an ID toolholder to get it back to X zero.
    I can use a coaxial indicator mounted in the chuck and sweep it and it will look fine. When I use a test indicator mounted on a mag base it is still way off. I realize you really have to be careful with spindle droop when using a mag base for this. Anybody have a suggestion what mag base or attachment works best with the least fighting droop?
    My thought is that with the co-ax depending on the length of the attachment and it is different how much you you move X to get the dial to move on it.
    I'm not sure this makes any sense, but are there any thoughts?
    Dec 2014
    CANADA
    British Columbia
    1,286
    361
    589
    The shortest stubbiest most rigid mag base you can get your hands on. If you search this forum for dialing in tailstocks you’ll find more than you’d ever want to read regarding indicator sag and how to combat it.
    Jan 2019
    Arizona
    807
    74
    281
    Quote Originally Posted by munruh View Post
    Ive noticed this also. one reason I believe is that when you hold a coax indicator so the dial doesnt spin just the slightest touch will change it.
    now if you put a rod on it to keep it from spinning if you watch the little u-shaped bracket that rides on the face of the houseing you can see how and why its not accurate. thats why I just dont trust coax indicators.
    That face has to be smooth as heck and not have any run out on the face or the c shaped part that rides on it. another words to many moving parts in a coax.
    I use a inter rapid .0001 indicator and a mirror. locate directly on the pin in a collet machine. in a chuck machine I use a er straight shank and and put the indicator in there. otherwise I will take the time and make a spider with a hole in it to accept the indicator.
    I never used a mag base in a lathe spindle for 30+ years of running and working on lathes because it just isnt going to be exact.
    sure might be faster and and easier. to be honest you will be just as close taking your O.D. tool and cutting the face and eyeballing it.
    There was a german company that made a coax that was extremely accurate it was electronic didn't refresh fast enough but it was nice. came out around 1996. you could touch the body with slight pressure and the needle didn't change. They were pushing close to a grand back then. cant remember the name.
  4. Likes munruh liked this post
    Jan 2015
    Alabama
    297
    221
    146
    Check into a Haimer Centro.
    Jan 2009
    Missouri
    101
    151
    30
    Quote Originally Posted by pmack View Post
    Aside from rigidity, OP doesn't mention resolution of the Co-Ax versus the test indicator. Co-Ax in .0005/ 3/4" dial is nothing like a .0005 or .0001 in 1-3/4" dial face.
    Mar 2009
    Eureka, CA
    3,808
    779
    1352
    I have a Blake which I used often time and felt secure in its accuracy. I just checked on the current price and almost messed my fresh Depends..$400 clams. I know for a fact that I didn't pay anywhere near that, although I bought my many years ago.
    Stuart
    Aug 2015
    Illinois
    1,458
    1062
    631
    I have a Blake clone. I use it to get close, then switch to a DTI to get balls on.
  9. #8
    Apr 2019
    AUSTRALIA
    5
    every dti I have ever used is useless for lathe turret alignment.
    try this as an example of gravity at work on small clock parts.
    mount a dti directly to a solid part in the horizontal plane via a clamp avoid the mag base,touch the needle onto the block and set the dial to "zero"
    now lift it above your head and rotate it upside down... I have found this to show more than 0.1mm of movement
  10. #9
    Jan 2017
    57
    16
    I thought you weren't supposed to measure upside down with a dti?
  11. #10
    Dec 2008
    New York
    10,234
    2656
    tram error. that is the center of a short tool tip and be different that the center of a long tool tip. hard to describe. just saying machine alignment often reason you can get different readings even with a rigid setup.
    by the way take indicator and rod setup (same length and type as going to use later) and mount on a solid pipe and zero with indicator at the top and rotate pipe and read indicator at the bottom. this sag amount is what you need to compensate for sag of indicator setup.
