True position callout .000 M to datum A M
Results 1 to 9 of 9
    Aug 2006
    greensboro,northcarolina
    2,557
    174
    676
    Default True position callout .000 M to datum A M
    What do you make of this? Part requires 100% inspection.
    Dealing with purchasing, military replacement part, no deviation allowed.
    Jan 2014
    Temecula, Ca
    3,280
    1398
    4289
    Looks like you need to get it right on the money.
    Your bonus tolerance is all you get
  3. Likes Booze Daily liked this post
    Nov 2014
    Florida
    5,677
    2251
    2827
    Quote Originally Posted by RJT View Post
    It is called out as 0.0 deviation at MMC (the M in a circle) = maximum material condition. I don't see datum A on the print, but am assuming it is centerline of the part? If so just be sure to turn both diameters in one chucking and you should be good to go.
    As far as no deviation allowed, well that is a purchasing/quoting screw up IMO that it did not get flagged. I imagine even inspecting with a cmm and tenth indicator, you will see something (even if it is just a slight bit of bearing play or whatever in the equipment). Might want to turn that diameter .0005-.0007" undersize to give you the little bit of play you will need for inspection...?
    Aug 2006
    2,557
    174
    676
    That's my thought too. Use MMC (go undersized on diameter by half the tolerance) as runout tolerance. Other datum is another diameter with .001 total tolerance, so i could pick up some there too. I'll be turning both diameters at the same holding, so I'm not worried about run out, just how to document it on an inspection report. Going to see if I can get purchasing to clarify through engineering. Never seen it toleranced this way.
    Jan 2014
    Temecula, Ca
    3,280
    1398
    4289
    there's really nothing to clarify, it's done like this all the time. In fact, I remember a gd$t quiz a while back whera tp of zero was given as a trick question.
  7. Likes Booze Daily liked this post
  8. #6
    May 2005
    AZ
    2,448
    238
    831
    This is a very good way to define the needed relationships, where close tolerances are required. The "zero"tolerance on the diameter's true position is modified enough with the MMC callout to describe that the part needs to be dead-nuts concentric, with a few tenths of diametral clearance allowed. Seems perfectly sensible for functional callout; whether you can hit the tolerance may be an open question. DAMHIKT.
  9. #7
    Oct 2007
    SPAIN
    4,353
    301
    175
    Where's "A"?
  10. #8
    Nov 2014
    Florida
    5,677
    2251
    2827
    Quote Originally Posted by Larry Dickman View Post
    Doesn't make it correct, or a 'good' way. I agree, nothing to really say about it except you usually see something like this and sweat trying to make them to print, and fast, and repeatable... then come to find out it is a clearance fit for some other component that has .02" "slop" in it
  11. Likes jz814 liked this post
  12. #9
    Feb 2008
    MI, USA
    915
    70
    376
    barbter is right, where is "A"?
    Seems A should be a diameter or bore. What is the tolerance of A? Edit: saw your reply, it is another diameter with .001 tolerance.
    My understanding of these .000 boxed dimensions (and I see them a lot) is you get your .001 bonus tolerance for the size of that diameter if you hold it to the minimum size, and you get some more bonus tolerance based on the tolerance of "A".
    EX: If A is a diameter with .001 tolerance, and you manage to put both diameters at the low, you'd get up to .002" TIR there.
  13. #10
    Oct 2007
    SPAIN
    4,353
    301
    175
    Quote Originally Posted by dandrummerman21 View Post
    My bad - i should have been clearer.
    I meant show us the pic of it on the print - it would help deciding how to detail it on the Inspection report
  14. #11
    Dec 2018
    Arizona
    45
    32
    I see this all the time with our customers. It's especially common on clevis ends of bellcranks for the holes in the ears. In this example the tolerance is .000 + the bonus of this feature based on its actual size and whatever the bonus is of -A- based on its actual size. We record it on the AS9102 as .XXX (whatever the measurement is, that's within the bonus tolerance) with the circled "m" after it indicating it is using mmc bonus.
    Sent from my SM-N960U using Tapatalk
