True Position Question
Results 1 to 4 of 4
    Apr 2021
    Washington
    Default True Position Question
    Hi All,
    Im curious if anyone has come across a true position callout that is to two datums, both datums being holes?
    Its my understanding that a hole used as a datum is like a coordinate system. How do you dimension something to 2 coordinate systems?
    May 2011
    New Jersey
    2,991
    300
    1648
    Looks like it's calling the holes as references.
    Apr 2013
    56
    5
    24
    Datum B is used to to orient the part about Datum A. If there was only the A Datum, you could put the hole anywhere around A at a given radius.
    Nov 2015
    582
    250
    Quote Originally Posted by JonFinn View Post
    ^This is the correct answer.
    If you really want to go letter of the law and be pedantic you could assume the part has some thickness is which case:
    Hole A sets the X, Y, and 2 axis of rotation. IE, if hole A isn't perpendicular to the face, this other hole ideally would be off by the same amount.
    Hole B sets the 3rd axis of rotation, and Z direction position is neither set nor relevant because the part is the same at all cross sections.
  5. Likes pb1 liked this post
