Unidentified indicator attachment
stevewatr
Stainless
Aug 9, 2013
Worcester County, Massachusetts
Recently bought this Starrett indicator and am intrigued by the attachment it came with.
I'm sure it could easily be a one off special purpose built jig, but on the off chance it has a particular known purpose or generic name, I thought I'd run it up the flagpole.
Steve.
Sent from my SM-J737P using Tapatalk
Almost certain it's a one off. Starrett made specials, but usually marked them as such. Seems clumsily designed to me as well - with screws on the triangular bits hard to reach.
Hello,
The screws that hold the triangles sections in place are allen cap screws, screwed in from the top side, with recessed heads.
You're seeing the bottoms of the screws, and the high resolution pics make it appear as if they are set screws, but those lines that look like screw slots are just some optical illusion mumbo jumbo.
Regards,
Steve.
Looks like a custom made tool for measuring a specific diameter
I've seen something very similar and it was made for measuring large dameters. With the one shown I'm sure Illinoyance is correct and it's for grooves otherwise "flats" would give a better "rest".
Maybe something like that would solve some of the "problems" Ox has when measuring very large diameters. A combination of angle and a depth micrometer? It'd probably "only" require knowing the correct angle and then using trig.
