Michael Moore
Titanium
- Jun 4, 2004
- San Francisco, CA
I recently bought this low-use Togoshi Seiki Rockwell hardness tester (photos in this folder on my website):
http://www.eurospares.com/graphics/metalwork/hardnesstester/
Anything that looks like rust is just a thick coating of LPS3 smeared over the metal.
It didn't include any documents. I found some generic instructions for another brand of tester on the Web and I think I'm clear on which sets of weights to use but that's about it.
There is a conical point in it now and a very small ball in a tube in the case, as well as a couple of test blocks. The point looks to be in good condition.
How do I use this? I'm guessing that I put the appropriate number of weights on the back (all three for Rockwell C), pull that lever on the top right forward, raise the knee pressing the point against the part until the small arrow points to the small red dot on the left of the dial, zero the dial to the "set" point, and then trip the lever to release the weight. Whatever number the needle points to when it stops moving is the hardness. Is that right?
If the needle doesn't match the rating on the test block, what do I adjust? There are some threaded shafts on that thing (hydraulic dash pot?) on the left side of the column, but I don't want to fiddle with them without being clear on what they are supposed to do.
FWIW, I paid $400 for this. They seem pricey and this is from a Japanese firm so did I get a decent deal?
thanks,
Michael
thanks,
Michael
