Viability and technique for ring gage repair
Results 1 to 6 of 6
    Feb 2018
    Colorado
    31
    49
    6
    Default Viability and technique for ring gage repair
    So a pawn shop i occasionally stop in had a massive set of ring gages. probably about 25 of them in a complete set between .5000 and 2.0000, problem being, that had a decent amount of rust on the bores. i've had some success repairing stuff with evaporust and then a short citric acid bath. curious if they are worth saving, to be used for rough gages after a quick ball or brush hone or if i will push their roundness to far out to be used for anything useful or if i would be better off using a dial bore gage setting tool with gage blocks. im leaning towards the latter, just tell me so i dont look at them again lol.
    Jul 2006
    Hillsboro, New Hampshire
    12,668
    2891
    8775
    I like ring gauges for checking the inside jaws of calipers. If these clean up reasonably well they'll probably still be fine for that purpose, given the low accuracy requirements (you're just checking that the jaws aren't grossly off).
    But for anything tenths related, I'd want to do a cleanup hone on a Sunnen or similar (i.e. a proper hone, not a drill-driven ball hone), then get them recalibrated to the new size. Likely too much effort and $$ for your needs...
  3. Likes seve7 liked this post
    Feb 2018
    Colorado
    31
    49
    6
    they wanted 1249 for them, i laughed and said you know these are basically ruined right? thats funny because i told the guy, its probably cheaper just to get new ones than fix these ones
  5. Likes sfriedberg liked this post
  6. #4
    Jul 2006
    12,668
    2891
    8775
    Yeah, that's more that $1100 too much. But hope springs eternal, maybe they'll find someone to buy them.
  7. Likes seve7 liked this post
  8. #5
    Nov 2014
    Florida
    6,185
    2451
    3075
    They were shiny... = expensive to a pawn shop! LoL... I might do $10-20 each for the set. likely a 1000+ grit paper would fix them up and still be within tenths (providing the rust IS just surface...)
  9. Likes seve7 liked this post
  10. #6
    Nov 2014
    Florida
    6,185
    2451
    3075
    These are really hard to beat for the price.
    https://www.mscdirect.com/product/details/92828045
    I would use 'real" gage blocks though. Takes a bit of finesse to swing to and fro/left to right to get the highest/lowest spot, but I used this tool to do bearing bores without issue.
    https://www.amazon.com/Fowler-536460...8835617&sr=8-2
