Vision system / CMM combo?
Results 1 to 16 of 16
    May 2017
    Minnesota
    1,003
    1206
    628
    Default Vision system / CMM combo?
    I'm looking at trying to get a combo vision system / CMM in here. What machines should I be looking at and how much should I expect to spend? We're a small medical device company, make some parts including bone plates and surgical implements in-house, and job out a ton of Swiss parts like bone screws and need to be able to inspect them reliably and efficiently.
    Sep 2015
    Ohio
    1,113
    668
    1092
    I think a CMM may be overkill for the typically small parts seen in medical.
    I would suggest a good comparator and a contracer.
  3. Likes Eric M liked this post
    Nov 2007
    Orlando, FL
    395
    838
    153
    You also need to realize (if you haven't already) that there will be a learning curve involved with new equipment. If you decide to go with a CMM, there will be the a learning curve with the CMM itself, AND with the software that the CMM runs on. IME, most CMM sellers will try to sell you a CMM with WAY MORE capabilities than you really need. There are manual and DCC (computer-controlled) CMM's out there, and they all have their "pros" and "cons". Depending on how familiar you (or whoever will be operating and/or programming it)are with them, it may take you a couple of months or more to be fully familiar with it. I'm not trying to turn you against them; just pointing out some things to help you make some decisions. Good luck!
    Nov 2014
    Florida
    3,728
    1539
    1764
    You can get a small micro-vu for around 15k I think. Not sure if that is the ballpark of what you are thinking or not.
    Micro-Vu Precision Measurement Equipment
    It would be a manual model, but they are very capable and not overly complicated to use IMO.
  6. Likes Eric M liked this post
  7. #5
    May 2017
    Minnesota
    1,003
    1206
    628
    Thanks for the replies. I have programmed Zeiss Calipso in the past (about a decade ago now), and I program 5 axis for machining now, so I'm not afraid of the software learning curve. Here are the reasons I think we need a vision system with a contact probe. We currently use a manual machinists microscope for inspecting bone screws, hexalobe driver tips, etc., and our inspection guy spends endless hours doing this tedious process over and over every time we receive a lot. This should be solved by an automatic vision system. For the bone plates and drill guides pictured below, we have angled holes and organic surfaces that I think can only be properly handled by a CMM:
    For the tapered threaded holes, I'm thinking make a dowel pin with a matching thread on one end, and the other end ground a set distance from the reference pitch diameter, and the hole axis and thread depth should be probe-able. Those can then be related to datum points on the organic surface.
  8. Likes Mike1974 liked this post
  9. #6
    Nov 2014
    Florida
    3,728
    1539
    1764
    If you have organic shapes like your pictures, you might even need a cmm with a scanning (?) head, which will raise the price even more. Curious as why you think you need a cmm AND a vision system (or I am confused with terms?)....
    I would *think* a cmm would do everything a vision system could do (dimensional), minus the obvious 31-62-90-xxxx zoom capability to examine visual features of a part.
    We had a large micro-vu at one place I worked (motorized/auto) that you could program and it would check holes and such, then flag them if they were out of tolerance OR stop the program when it encountered a 'bad' hole/feature. For something like that I think it is much faster than a cmm because it does not have to physically probe hole locations.
    I think it was one of these models. I think the table was around 3' x 6', maybe the 1051/52 model? They start around 80k from the website...
    edit: it appears they do offer a touch probe, not sure how that affects price, or if it is comparable to a bonafide cmm...
  10. Likes mhajicek liked this post
  11. #7
    May 2017
    Minnesota
    1,003
    1206
    628
    Well, what I'm thinking, is that the vision system would be great for quickly checking the bone screws, including the tapered thread on the locking head. I can whip up a tray to hold 100 or so screws at a time, lay them in, and run the inspection program. I've seen machines that are primarily automated vision systems but that have a CMM probe as well; I'm thinking that would be great for getting the angles and positions of the holes in the plates (with pins in the holes to beep on), plus a few datum points on the organic surfaces. Yes, to fully characterize the surface I'd have to scan the whole thing, but I think if I specify some number of points to beep on it should be sufficient.
    Thanks for that link, they list prices!
  12. Likes Mike1974 liked this post
  13. #8
    Nov 2014
    Florida
    3,728
    1539
    1764
    Quote Originally Posted by mhajicek View Post
    Right?!? LoL that is getting harder and harder to come buy with industrial equipment....
  14. #9
    Aug 2019
    Michigan
    You might try looking at a Keyance system. I've run one before, it has an extensive thread program built in. It makes quick work on screws. Doesn't have a touch probe though. I run a Hexegon Global Advantage with a vision head and a touch probe on it that does an very good job.
  15. Likes greggv liked this post
  16. #10
    Feb 2006
    so cal, usa
    603
    215
    142
    second on the Keyence units.
  17. #11
    Sep 2014
    Minnesota
    189
    76
    116
    At a previous employer, we purchased a hexagon "Dual Z" cmm with rotary.
    Optiv Dual Z | Hexagon Manufacturing Intelligence
    We used it to measure organic surfaces, and custom thread features. I think it cost around $140k but I do not remember. It was a good machine, and I think would work very well for the type of parts that you make.
    I vote against the Keyence. It would be good for some of the bone screws and similar, but would fail miserably at the bone plates. I could be wrong, because my exposure is limited, but a straight vision system is for very specific work.
    If you wanted a little demo, Keyence is always willing to bring a machine out. The small entry level version costs about $70k I think. We have one here at the shop. I could probably get one of my quality people to give you a demo if you didn't want the sales pitch.
  18. Likes camscan, mhajicek liked this post
  19. #12
    Jul 2009
    hope,in
    651
    30
    39
    Werth makes a combo Vison CMMM. Roughly $700K
  20. #13
    Dec 2003
    Washington
    4,675
    2191
    3995
    This might be a good application for a small robot combined with a Keyence or Cognex vision system and probing station. We are building an aerospace fastener manufacturing and inspection system now that will do closed loop adjustments to the forming section based on inspection results.
  21. #14
    Jan 2012
    Kentucky, USA
    19
    Renishaw offers two 5-axis probes heads. The Revo and PH20. The Revo is a scanning head and the PH20 is touch points only. They also offer a vision probe. Might be worth a look. I would think they would be able to be installed on most cnc cmm frames.
    Ken
  22. #15
    Oct 2013
    Rochester, NY, USA
    114
    43
    Keyence has a brand new model which has a very wide field of view and I think does very fancy 3D analysis.
    maybe one of these:
    Microscopes / 3D Surface Profilers | KEYENCE America
  23. Likes mhajicek liked this post
  24. #16
    Nov 2018
    ITALY
    Dear mhajicek,
    there are a lot of solution for your reques.
    A traditional cmm as for example 600 x 500 x 500 with probing system and vision sistem complete with software is about 65k€
    This is a fully equipped machine but may be you could save money with different solution/ dimensions.
    For example if you don't need a motorized head you can save up to 12k€.
    If you need some more information and you can give me some more details regarding object to be measured I would be pleased to support you
    best regards
    Alessandro Rotondi
