rimcanyon
- Sep 28, 2002
- Salinas, CA USA
i.e., is an ultradex used only for calibration purposes, part checking and optics, or is it intended to be used as a rotary table for machining? Or does the answer depend on the model?
I have a 5" one (not sure what brand it is, so I am using ultradex in the generic sense for a serrated tooth divider). It is really nice to use, easy to change settings, but I don't think it is intended for machining. More likely it is intended to be used as an inspection stage for an optical comparator, or similar. Here are some photos with the ultradex and a bottom from another:
What is the purpose of the metal bracket on the side of the ultradex in the photo above?
