Where to find foaming surface plate cleaner?
Results 1 to 15 of 15
    Nov 2015
    413
    156
    Default Where to find foaming surface plate cleaner?
    There are plenty of references in this forum to foaming surface plate cleaner, but now that I'm trying to buy some I can't seem to locate any.
    A few jobs ago we used DoAll gage block cleaner in a spray can with success. The description mentions "Cleaner is specially formulated with lubricity agents" and the MSDS mentions soybean oil. While I've never noticed an issue, that doesn't seem like the right thing to be spraying on a granite plate.
    Does anyone else have another spray on foaming cleaner they like?
    Jun 2015
    Minnesota
    558
    11
    195
    It's not foaming, and not sure why a surface plate cleaner needs to be, but I've used the surface plate cleaner from Starrett for many years without any fails. I don't know what's in it or why it works perfectly, but it does. Afterwards it's like the table is new all over again. Give it a try.
    Dave
  3. Likes tdmidget liked this post
    Aug 2006
    greensboro,northcarolina
    2,508
    166
    649
    I'll second the Starrett cleaner. We have used it for years.
    Dec 2014
    CANADA
    British Columbia
    1,288
    361
    590
    Don over at Suburban tools recommends household ammonia.
    Jump to about 3 minutes in to get past the humour.
    Dec 2004
    uk
    14,053
    4552
    6712
    Honestly its granite, anything but strong acids won't bother it, even then some granites are reasonably acid resistant, but spilling a half pint of hydrofluric is a problem.
    I have had good luck with the foaming computer based cleaners, they remove coolant residues and oils really well, they do have some amonia and they even work on old dried out cosmaline. The foaming nature realy kinda lifts dirt out of any textured surfaces, thats kinda the idea behind it.
    Don't know if you get it over there but Ambersil foaming cleaner works great, can will go a fair old way too.
    Aug 2005
    CT
    7,982
    356
    1986
    I have a few aerosol cans of DoAll Kleen-Surf cleaner left, and it is of the foam type.
    I like it better than the Starret, but for the life of me can't find these anymore in the aerosol format.
    They still make it in bottles, but do not know if it is still of the foam type. DoALL Kleen-Surf DoALL Sawing
    Jan 2009
    Missouri
    102
    151
    31
    There are commercial spray and liquid solutions that work; I'll bet Starrett outsells all of them. Some use window cleaner.
    But I use plain lanolin hand cleaner, and lintless knit cloth. Ammonia maybe twice a year.
  9. #8
    Sep 2015
    Tennessee
    565
    280
    434
    Quote Originally Posted by Hazzert View Post
    Love Don to death, but now your plate smells like cat piss.
  10. Likes stevewatr liked this post
  11. #9
    Aug 2013
    Worcester County, Massachusetts
    936
    362
    123
    This thread brings to mind a question I had.
    Care and cleaning of a cast iron surface plate. I picked up a nice one a while back.
    Cleanings a no brainer, but the cleaner it is, the faster it oxidizes. So I keep it sprayed with a lith film of lithium grease between uses. I'm thinking of maybe making a cover.
    I've seen plywood ones, but wood holds moisture.
    Any ideas?
    Steve.
    Sent from my SM-J737P using Tapatalk
  12. #10
    Mar 2017
    LATVIA
    560
    143
    276
    I bought a cast iron surface plate couple years ago from Switzerland, and it came with a shop made aluminum cover, there was and still is a sheet of thick paper under the cover, sort of like cooking paper, I use it for spotting with dykem hi-spot, clean with mineral spirits, not a spot of rust on it so far
  13. Likes stevewatr, Toolmaker51 liked this post
  14. #11
    Nov 2002
    St.Louis, Missouri, USA
    2,089
    125
    469
    Plain old aerosol glass cleaner seems to work well on granite, acetone cleans real well but isn't real friendly odor or health wise. All I'm looking for is a dust and oil free surface so the tools slide on the surface without scratching.
    For cast iron; I worked for a government contractor that had several and BonAmi powder cleanser was the cleaner everyone used on those iron plates. Those were used 24/7 years on end and don't remember any particular wear issues caused by it.
    Dan
  15. Likes stevewatr, Toolmaker51 liked this post
  16. #12
    Aug 2005
    Tucson AZ
    6,485
    10038
    3049
    Quote Originally Posted by 13engines View Post
    Dave
    Also I found that it will clean Mics and other instruments without any harm. Mine have a knurled thimble that would fill with dirt and goo. It cleaned them perfectly.
  17. Likes stevewatr liked this post
  18. #13
    Aug 2013
    936
    362
    123
    Quote Originally Posted by Danny VanVoorn View Post
    Dan
    Kind to think of it, the aerosol spray on glass cleaner I buy at NAPA called Sprayway is a foaming cleaner! Judging by the smell, its ammonia based. Never thought to try it on tools before. Thanks!
    Steve.
  19. #14
    Mar 2005
    Kansas
    7,967
    491
    3801
    I am certain the surface plate cleaner Rock Of Ages sold was rebranded Dow 409 bathroom cleaner.
  20. #15
    Feb 2011
    Washington
    25
    it's not a foaming cleaner, but we have no complaints so far...
    we bought a special bottle of Simple Green surface plate cleaner. After that first bottleran out, we just used regular Simple Green (diluted)....ta da.
