10 EE collet nose removal
Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Jun 2013
    452
    369
    193
    Default 10 EE collet nose removal
    My new to me 1971 square dial has the pictured spindle arrangement. How do I remove the collet nose in order to install the D1-3 chuck?
    All comments welcome. Thanks fellas.
    Oct 2006
    Woodland Hills, Ca. and some times Hutchinson, Ks.
    2,447
    20
    642
    It is held in the spindle taper, you need a knock out bar. Something solid bout 1" in diameter through the back of the spindle, usually just the weight of the bar is all that is needed tap moderately. Have a hand over it so it doesn't pop out and hit something.
    Steve
  3. Likes ezduzit liked this post
    Feb 2016
    1,964
    1357
    786
    A blunt bar and a hammer from other side of headstock, to get it off taper. Might want a box or something to catch it. A piece of round stock to fit down inside of spindle, but large enough to fully contact the adapter so you don't ding it when you give it a whack.
  5. Likes ezduzit liked this post
  6. #4
    Jun 2013
    452
    369
    193
    Duh! Thanks fellas. I really should have been all over this. My bad. Was afraid to damage something in my ignorance.
    Is there any reason to remove the entire collet closing mechanism when using the chuck? Never had to concern myself with this setup before. Thinking the inner tube might not want to be rattling around in there.
  7. #5
    Oct 2006
    2,447
    20
    642
    You can't knock out the spindle nose with the draw bar in the spindle.
    Steve
  8. Likes ezduzit liked this post
  9. #6
    Jun 2013
    452
    369
    193
    Quote Originally Posted by Steve in SoCal View Post
    Steve
    Got it. Figures that the ID of the drawbar prevents getting the knockout bar to contact the nose.
  10. #7
    Sep 2002
    Salinas, CA USA
    4,786
    521
    425
    Did the lathe come with a pair of drawtube hanger brackets on the back side of the headstock? I've seen some lathes with Monarch lever-op collet closers that had them and others that did not.
  11. Likes ezduzit liked this post
  12. #8
    Jun 2013
    452
    369
    193
    Quote Originally Posted by rimcanyon View Post
    It came with this JFK collet closer setup installed. But it does have the brackets on the back. And I only just now learned what needed to be done to allow the use of the D1-3 3-jaw chuck it came with. Also bought a 4-jaw for it which has the D1-3 backing plate.
  13. #9
    Sep 2002
    Salinas, CA USA
    4,786
    521
    425
    Those brackets are for the knock out bar.
  14. Likes ezduzit liked this post
  15. #10
    Jun 2013
    452
    369
    193
    Thanks. Always wondered what they were for when I've seen them on so many lathes.
  16. #11
    Feb 2002
    Peralta, NM USA
    5,975
    59
    611
    Here's a shot from an old manual (Sunstrand hydraulic drive) showing the knockout bar in place:
  17. Likes ezduzit liked this post
  18. #12
    Jun 2013
    452
    369
    193
    Those bar hangars are on the back of mine. The front looks like this.
  19. Likes TheOldCar liked this post
  20. #13
    Jan 2020
    51
    10
    11
    Quote Originally Posted by ezduzit View Post
    can you give a little description / pictures of the those casters/skates?
  21. Likes ezduzit liked this post
  22. #14
    Jun 2013
    452
    369
    193
    Quote Originally Posted by Jdub63 View Post
    This is the seller's eBay photo (colored red to distinguish between his other models; the actual skates are black bodies). eBay seller "santschifarms". I paid $220 for a set of 4. Great seller.
    Cut my first chips today on the Monarch! Very quiet and nice overall. Had a bit of a start when I first fired it up and, when nothing happened after putting it in both forward and reverse, finally figured out that the speed control goes all the way to zero!!! Doh!
  23. Likes Jdub63 liked this post
  24. #15
    Oct 2006
    2,447
    20
    642
    The knock out bar hangers are on the back of the machines with push button stations on the front right corner of the base. Not sure when the change occurred, earlier maybe even later round dial machines? That Sundstrand machine is the only one I recall seeing with the bar in front.
  25. Likes ezduzit liked this post
  26. #16
    Mar 2002
    dallas,tx
    2,690
    757
    557
    My 59 WIAD has the bar in front, I thought they all did up to the Modular, as the bar wouldn't work with that door.
  27. Likes ezduzit liked this post
  28. #17
    Sep 2002
    Salinas, CA USA
    4,786
    521
    425
    I have one question about knock out bars. Are the ones for 10EE all the same length? i.e. if you have a 5C lever-op collet closer, it extends the spindle 4-5". Even if you remove the draw tube the regular length knockout bar is too short.
  29. Likes ezduzit liked this post
  30. #18
    Feb 2002
    Peralta, NM USA
    5,975
    59
    611
    That's kind of strange. I've always thought that my lathe had been retrofitted for a collet holder since it has a couple of setscrew holes cut on the outboard end but it's pretty normal in length.
    Anyone have both and can measure the spindle length?
  31. Likes ezduzit liked this post
  32. #19
    Jun 2013
    452
    369
    193
    Total length of mine, as pictured, from the left end of the collet closer to the right end of the collet nose is about 31"; 5-3/8" of that is what extends beyond the lathe's end cover.
  33. #20
    Feb 2002
    Peralta, NM USA
    5,975
    59
    611
    I think the confusion here is that (so far as I know) the knock out bar won't pass through the collet draw bar. It shouldn't have to as the taper is being blocked by the collet draw bar. The exception to that is if you have a 12 Jarno to 5C adaptor (is that possible?) and have a draw bar shortened for that. In that case you might get something into the 12 Jarno taper with the collet draw in place and would have to have something custom for the knock-out bar.
    In either case the 10EE *spindle* is the same length.
  34. Likes ezduzit liked this post
