10ee acting funny
I think I know what's going on, but I need to see a photo of the inside of your DC control panel. (It's the big box in the headstock end of the base, next to the spindle motor.)
Do you see sparking coming from the spindle motor's commutator?
Are any of the relays in the DC control panel cycling on and off in time with the pulsing of the spindle?
Cal
My MG set is the last version, but, if the earlier exciter uses a pair of, or split brushes, after time, they will wear a ridge down the middle of the commutator, that can be seen by the bright line in the photo.
The ridge, when too tall, will tend to push the brushes apart and stick in the holders, and causing low voltage resulting in surging.
In the photo Iam using an Ideal Electric commutator dressing stone that I glued to a stick, to remove the ridge, and smooth the commutator.
May be something to have a look at.
Cal
I have left for the day but will check in the AM.
I believe that I was hearing something electrical cycling but can get better info tomorrow.
Sent from my SM-G950U using Tapatalk
I will check it out. That is on the right side when facing the machine?
I have seen more sticking brushes than any other problem. Much of the time a therapeutic wiggle is all that is needed. Donie, you must put a lot of miles on your lathes. I haven't seen the ridge problem or any appreciable commutator wear on machines in a job shop with constant use. One modular is the lathe of choice for one machinist. The owner gets upset when it has problems because that machinist on that lathe is a money machine. The fellow can run any machine in the shop, but with three Moris, and a Hwacheon, a small Harrison and an MG 10EE besides the modular, that is his choice and the way he turns out work, we try to keep him happy.
Bill
Sorry guys. Did not get a chance to look today as I am falling behind in work. Hopefully tomorrow will be better.
Thanks for all the suggestions so far.
After my exciter suddenly needing a flash every 2 months, I removed the armature and turned the commutator bars down past some burn/flash gouges. Then carefully cut the mica grooves down with jeweler files, chamfering the corners just a bit. The mica had been sitting higher the bars! I don't remember the abrasive I used for final turned finish of the bars (googled it, but made sure it wasn't crap sandpaper that would embed into the copper. I also made sure to clean away dust afterward. Before this I had dressed the commutator while still inside the exciter, but that finally wasn't enough. Even new brushes had worn at an alarming rate! I also checked, adjusted, and checked again that the brushes had free play.
The professionals use what looks like a miniature slitting saw, perhaps 3/8" diameter so they can cut a groove close to the larger part of the commutator where the wires attach. Then sand the burrs with 600 grit wet or dry. I don't do enough commutators to invest in professional equipment so I grind the set off a hacksaw blade on the end where the teeth are pointing toward the center of the blade so it cuts on pull. I cut the slots and deburr with 600 grit, blow the dust out and tape a strip of 400 grit around the commutator with the grit out. I install the armature in the motor with the brushes and form them by rocking the armature back and forth. Remove the strip, blow the dust out, and you are ready to go. Forget about embedment. Its an old wives tale that won't go away. Hans Fischer, the honing guru at Sunnen did tests. He knew a lot more about the subject than either of us and had all the equipment. When I asked him about it, his response was "Oh, that again." He found that you had to press the grit into the metal almost deliberately. Grit rolling across a surface in hand sanding simply will not have enough pressure to make it stick. Forget it. You probably would be best to mount the armature in a lathe and wrap the sandpaper with a thumb and forefinger applying pressure, the purpose being to round the corners of the slots slightly (like a couple of thousandths) to keep them from cutting on the brushes.
Bill
Thanks for that post, I totally feel for the embedment scare, which led me to never divulging what abrasive I used. :dunce:
After it was all back together, I made sure to seat the brushes with sandpaper as you said.
So I finally got around to digging a little further on this today.
Motor on the right u see the tail stock fires and runs consistently.
Pulled the covers and noticed the magnetic switches? Kicking in and out. Both directions. They were very dirty so I pulled them apart and cleaned them. Put it back together and the lathe is still behaving the same. Spindle kicks in and out.Tapatalk Cloud - Downlaoad File 20190717_164140.mp4
Cal
Pic attached
It does not have split brushes.
Pic attached
It looks like the DC control panel has been replaced at some point. That's the type of panel that was used on square-dial and WiaD 10EEs. What you have is a known problem with "Resistor B-E" in the upper-right corner of the panel. $30 worth of parts and you'll be back in business.
See this post: Start up problem with m/G machine?
If you need to use the machine while you're waiting for parts to arrive, you can jumper around resistor B-E, just be careful not to plug reverse the machine, as the jumper will disable the anti-plugging circuit.
Cal
