In the video shown below (cross-feed friction group) I am getting very little travel. I have spun the gears and they do all work correctly but I have to hold this handle down to keep the contact or bang it with my hand. The longitudinal works just fine. There is no amount of adjustment I haven't tried on the nut to get it right. Since one can never be 100%, I am 98-99% certain that everything on the shaft is in the correct order as I checked it several times as I was having trouble getting the pin in the end of shaft collar.
[video]https://batlgroupimages.blob.core.windows.net/accessibleimages/10EE_CrossFeedFrictionGroup_ShortTravel.MOV[/video]
Any thoughts appreciated.
Second problem.
How on earth do you get this new oil drip line in? I spent 90 minutes trying about everything I can think of. I was hesitant to take it out but it came out so easy I figured it would go in easy. (Wrong!)
Assuming I CANNOT get it in, are there any work arounds?
Thanks, I need to finish this up so I can get to the gearbox
Second problem.
